Old 09-10-2025, 01:56 PM   #1
CraigG
Liked 9 Times in 8 Posts
Default Finding Centerline 72 GTO GM A body to square up rear end
Hey Everybody,
I'm trying to find centerline on 72 GTO With stock frame for measurements
Would it be halfway between?
Outer rocker panels
Center of transmission or transmission crossmember
Center of stock frame
Thanks, Craig
CraigG is offline   Reply With Quote
Old 09-10-2025, 05:41 PM   #2
cordoba13
cordoba13's Avatar
Liked 14 Times in 9 Posts
Default Re: Finding Centerline 72 GTO GM A body to square up rear en
most cars I have seen have offset for steering box/engine clearance, not sure about GTO?
cordoba13 is online now   Reply With Quote
Old 09-10-2025, 10:36 PM   #3
CMcAllister
Liked 929 Times in 263 Posts
I would drop a string line from 4 or 5 different places on each side of the frame, from front to rear. Obviously use the same point on each side - suspension mounting points, factory locator holes, etc. Mark on the floor and find the center. If they all don't fall on the same line, double check your locations. And hope the car hasn't been hit.
Driveline is offset to the right. Don't recall the measurement but should be parallel with the chassis centerline.
Old 09-10-2025, 11:11 PM   #4
mike britt
Liked 66 Times in 31 Posts
If you're trying to find centerline of the body, use a plumb bob from the trunk lock to the floor and the center of the grill to the floor.
mike britt is offline   Reply With Quote
Old 09-11-2025, 10:48 AM   #5
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Originally Posted by CraigG View Post
Hey Everybody,
Outer rocker panels
Thanks, Craig
https://www.chevelles.com/media/68-7...ensions.15066/
Old 09-11-2025, 11:19 AM   #6
Troy Henderson
Troy Henderson's Avatar
Liked 130 Times in 42 Posts
Originally Posted by rallye bob View Post
A nice way to do it is to use the holes in the bottom of the frame shown in the link above. Then, you can drop multiple points down with a plumb bob to the ground on both sides. Measure across to get centers than take a string or laser and draw the centerline thru them.
Troy Henderson
Henderson Race Shop LLC 816-520-5389
www.hendersonraceshop.com
Troy Henderson is offline   Reply With Quote
Old 09-11-2025, 03:37 PM   #7
Hacksaw
Liked 314 Times in 177 Posts
Pretty sure the engine centerline is offset to the pass side by 5/8".
Old 09-11-2025, 06:13 PM   #8
I seem to remember that the factory shop manuals had those frame directions in them. If I am recalling correctly then the GTO material should be easy enough to find.
Old 09-12-2025, 12:03 AM   #9
FED 387
Liked 335 Times in 182 Posts
supposedly in all GM A-Body cars the engine is installed on the centerline NO offset from the factory --HOWEVER the pinion center was offset 1/2 inch to the passenger side of the vehicle--- not sure but what has been said-- might want to google it see what you can come up with
Old 09-12-2025, 11:02 AM   #10
CraigG
Thank you guys - very Helpful!
