Old 06-11-2008, 04:26 PM   #1
JRyan
Liked 112 Times in 31 Posts
Default 71-73 Mustang front disc brakes
Wondering what you guys are using with these cars? Trying to find something that doesn't need to much modifying to make work. Any ideas?
Rick Ryan
Old 06-11-2008, 04:46 PM   #2
Smitty
Smitty's Avatar
Default Re: 71-73 Mustang front disc brakes
Rick,
Terrance Smith from Florida, I thought you were gonna get back to me about the car....I got it ready to run in SS/IA or GT/EA, hope to hit the track with it around the first of the month and run at the race in Reynolds at the the end of July.
Smitty
oh as for brakes, I have the stock big 11 inch rotors on my car, have been looking into light weight alternatives but not sure what will work with 3300 lbs.
Smitty is offline   Reply With Quote
Old 06-11-2008, 05:23 PM   #3
SSDiv6
Originally Posted by Smitty View Post
Rick,
Smitty
Your choices for light brakes that will stop your cars are as follows:
Wilwood P/N 140-9054-D with the SRP rotors - About $775.00
http://www.wilwood.com/PDF/ds505.pdf
or
Lamb P/N #172A - $1280.00 $$$$
Terrance: You have a PM.
SSDiv6 is online now   Reply With Quote
Old 06-11-2008, 05:47 PM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Rick, You will have to swap out your spindles for ' 69 drum spindles for Strange discs, also for Wilwood,I believe. ....the early spindles also require the early tie rod ends also. .....Tom
Old 06-12-2008, 12:40 PM   #5
Bill Harris
Liked 26 Times in 13 Posts
I put the Wilwoods on my '71 by changing the spindles and outer tie rod ends. I used '68 drum brake spindles but I think any '67 to '70 drum spindles will work. Everything bolts right up, no problems, stops on a dime.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 06-12-2008, 05:11 PM   #6
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
Thumbs up Re: 71-73 Mustang front disc brakes
I have just installed the Strange kit for 65-69 Mustang on my Maverick drum brake spindle. The only modification required was to change to larger bearings. The cups share a common o.d. and will interchange in the hub....the 71-73 Mustang spindle diameter is the same as the Maverick I believe.
Dave Turner
SS/GT #1153
Old 06-12-2008, 09:55 PM   #7
vic guilmino
Liked 56 Times in 21 Posts
Red face Re: 71-73 Mustang front disc brakes
i have a 71 mustang and it had drum brakes
i put aerospace on and they are great
did not have to chance anything
vic guilmino
71 mustang 429 scj
Vic Guilmino 1129 STK
