Old 06-20-2008, 02:19 PM   #11
mannymen
Liked 13 Times in 7 Posts
Default Re: Ford Techs--7.3 Ford super duty Diesel smell
Did you find out where the fuel smell was coming from? Having the same issue with my diesel
N/A
mannymen is offline   Reply With Quote
Old 06-23-2008, 10:22 PM   #12
FED 387
Liked 334 Times in 181 Posts
Well as strange as it may be the smell just stopped tonite---Nothing at all--I did check what looks like a "hose" from the fuel filter cannister going down to the ground and wiggled it a bit nothing came out ---But maybe it was enough to let any built up pressure or water in there escape---Will keep all posted if it returns but for now it is gone---Comp 387
Old 06-23-2008, 11:36 PM   #13
srcamaro
check the forums at dieselstop. if i recall there was somting that would leak and puddle in the intake valley under all the crap on thost motors.
srcamaro is offline   Reply With Quote
Old 06-24-2008, 12:17 AM   #14
Tim Ellis
Liked 7 Times in 6 Posts
Smile Re: Ford Techs--7.3 Ford super duty Diesel smell
My f350 startted smelling like diesel too, as I recall it was the water drain valve on the fuel filter system. I believe it is plastic, I bought one from Ford, then I had them install it too because its kinda hard to get at. Common wear out item. Mine has 230,000 miles. Very good truck.
Tim Ellis is offline   Reply With Quote
