Old 06-25-2008, 12:18 PM   #31
Signman
Liked 269 Times in 99 Posts
Default Re: Considering going Stocker Racing
Near the end of my stocker project.
You can purchase an existing car and go racing.
A state of the art, fresh car is not going to be for sale for cheap.
If it's cheap, expect to update and freshen it.
It is a tremendous amount of work / time / money to build what could be a state of the art,competitive car. I have spent more than expected knowing how much was saved by research, help from others who know more, and calling in some favors. it pays to purchase good parts once if possible. When you build it yourself you know what you have therefore no surprises. (The seller told me it has lightweight trans and ring & pinion........ You don't know you have it till you look.... closely)
The truth be known to build a good consistent 10 second footbrake car these days costs 20K.
A competitive stocker built for 20-30k should not be considered a lot of money. If you pay to have all the labor done as well as purchase parts, even at racer discount, it will cost 50k easy.
Old 06-25-2008, 01:54 PM   #32
THE LEGEND
Talking Re: Considering going Stocker Racing
Jack,
I agree with your last post. It all depends on what you want. If you want pretty and fast you'll spend a lot.
If you want Pretty Fast you'll spend some.
If you want #LAST qualifier it will be "Less Expensive"
Speed cost how fast you want to go depends on how much you want to spend.
Chip
THE LEGEND is offline   Reply With Quote
Old 06-26-2008, 12:35 AM   #33
Bushwacker
So...You want to go stocker racing in the New Enhanced NHRA .... Tell me why havent your friends & family had you committed for Mental Evaluation????? LOL
Bushwacker is offline   Reply With Quote
Old 06-26-2008, 05:30 AM   #34
Grant Eldridge
Grant Eldridge's Avatar
Lots of great advice already posted. Might be a good idea to look at your local competition in the class you hope to run and first decide how fast you need to run. If you can get away with .5 under, you might be able to carefully put together a car with a good combination, decent machine work and not too expensive parts. I started out with used TRW pistons and flogged it down to .6 under after a year. But, to go 1+ under, in my opinion, everything in the short block had to go high dollar, index crank, high dollar pistons, exotic ring package, many thousands of dollars more just in parts plus more machine work, etc. Now, to go 1.20+ under you'll need expensive step or better headers, merge collectors, great trans and converter, excellent shocks, quality traction device, radials, high dollar carb, mondo fuel system, etc. These are just examples, there's lots more but you get the idea...To figure all this out, you'll need tons of great advice from guys that are fast, and tons of money to cycle multiple parts through the car to determine what works best for your particular combination. For example, I cycled 7 converters through my car in one year to get the best one, then went to a metric trans and bought three more to get one I felt worked well, these are around $1000. each, of course the others can hopefully be sold to get some money back. The same goes for most of the other parts on the car, you have to experiment, it's a lot of hard work, time and effort unless you are very fortunate and get it right early on. Someone posted to do it once and buy the best first, great advice! Otherwise you're re-doing each system over again as you learn and improve. My fuel system went from small to medium to large pump, then large to larger to return style for lines and regulators. If I'd put the best stuff on first, I'd have saved money and time, as well as eliminating a possible problem area. Not to discourage you, it's very rewarding if you enjoy the challenge and can invest the time and money.
My opinion, buy the fast car where someone has done all the above, you'll be years of effort and many, many thousands of dollars ahead. There's a limited market for these specialised cars, so there are cars available if you look that really should be much more than what they will actually sell for in today's market. Just my 2 cents worth....
Grant Eldridge is offline   Reply With Quote
Old 06-26-2008, 06:56 AM   #35
bsa633
Banned
Buy or build a car that you really like and want ...when you are out after first round...you will still feel somewhat good when you take the car home...it will make it more enjoyable in the long run and easier to spend the all that money! If you like to work on the car...then build one,then you will get the parts and pieces YOU want and where YOU want them...but if you are happy just to race in stock..BUY ONE!
bsa633 is offline   Reply With Quote
Old 06-26-2008, 12:50 PM   #36
Jeff Lee
Jeff Lee's Avatar
Grant is right on in his assesments. The only thing I would ad to this or any other post BUY THE USED RACE CAR ONLY AFTER WATCHING IT RUN AND THEN ONLY AFTER YOU HAVE SPENT A SOLID 1/2 OR FULL DAY INSPECTING THE CAR WITH A KNOWLEDEABLE FRIEND, PREFERABLY WITH ACCESS TO A LIFT (TO CALM DOWN YOUR EXCITEMENT).
A frind of mine just bought a car from across the country that ended up being only about .400 slower than reported (after taking into account weather condition variations). I told him to schedule a track appearance but he didn't. He did get a nice car at a reasonable cost. But it was full of poorly repaired / burnt wiring, loose suspension components, a fuel system that consisted of factory 5/16" lines coming out of the fuel tank mated to larger lines with a nice 90 degree kink in the 5/16" line and a stall convertor rated at at least 1000 RPM higher than what is required for the application (which also had an efficiency rating that calculates to only 86%; 95% or better being preferred). And now it looks like everything may be up to par but then the ring gear broke. Now it looks like everything is repaired or replaced but it's summer here in AZ and it's to hot to evaluate the changes.
And in the end it looks like the car will serve it's purpose. But it's extremely frustrating to buy a used car and find you need to spend not so much money to get it fixed (because it is a used car) but the time in trying to diagnose the problem area's (in this case there were many). At one point you could have picked this car up for free, the new owner was that disappointed.
So like I said, check it out not once but twice and if things aren't as claimed in the advertising, walk away or re-negotiate! Or build yourself, which is what I've always done. But be prepared to spend 3x from your best calculations in bothe time and money.
Good luck. It's not as bad out there as people make it sound...!
Jeff Lee 7494 D/S '70 AMX
Old 06-26-2008, 06:46 PM   #37
Greg Hill
Liked 279 Times in 68 Posts
The good thing about building your own car is that you get to build it like you want. If I bought a car I would probably end up re-doing everything and would spend more money in the long run.
Greg
Old 06-26-2008, 07:54 PM   #38
THE LEGEND
Greg,
Did it to 3 different cars. The new owners of 2 of the cars did it again. The 3rd just got it last week.
Chip
Old 06-26-2008, 08:50 PM   #39
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
I started drag racing in 1966 with a Jr. Stock '57 Chevy sedan delivery. Every once in a while I get attracted to go back to my early days. Bad idea.......A few years ago I did it again. This time....I had to have one of these wheelstanding EFI 10 second late model F- bodies. Sold my dragster, bought a good roller that came with a lot of parts. Built my own engine, tuned the EFI myself.....no dyno time......ran some good numbers here and there. Felt like I was doing ok......needed to spend more time and money getting it better......rules changes.....economy changes...... basic facts...Stockers are not good bracket cars...racing it locally to tune it and your driving means running against todays bracket cars.....your at a number of disadvantages there. So that leaves you with competing at NHRA races....costs are way up to travel and race.....ok so it all costs a lot no matter where you go and if you enjoy running with the stocker crowd...great. but for me it wasn't working so I sold my stocker and went back to a dragster...way more "user friendly" and I enjoy it a lot more.....power and speed makes me smile...wheelstands are fun...but as someone I worked for once said..."you could do a wing walk while racing that car"......Too Friggen slow for the time and money spent.......Stock is great but you gotta really love it.........
Rich Biebel
S/C 1479
Stock 147R
Old 06-27-2008, 10:08 PM   #40
Bushwacker
Many people have bought fast stockers....rebuilt them thinking I can make it even faster....
And they ran slower!!!
