Old 08-02-2008, 10:00 PM   #11
Bub Whitaker
Default Re: Steel head shim ???
Originally Posted by Woodro Josey View Post
Yep excuse me Bub, i am not saying thats the right thing to do, but the amount of flow lost to having bent valves, i think i would face the valves if all else has been tried, either on top side or with a valve refacer, whatever he has access to,! But then what do i know!!!!!!! lol
You know too much! hope I can retain as much as you've forgotten, but your correct that is the easy quick fix... I'm just use to doing these stocker engines and makin the heads fit the shortblock after it's assembled
Bub Whitaker is offline   Reply With Quote
Old 08-03-2008, 12:08 PM   #12
art leong
Thanks guys. I can't do much with my existing pistons The cam I'm running would check legal in a stocker.
And I'm running a modified production motor class. I talked to JE and they can make a piston for me that will take up to .500 lift with a normal head gasket .045 and have 14 1/2 to 1 compression.
But that will be over the winter.
For now I'll just try to learn the ins and outs of this combo. Then build a killer motor and really learn how to go slow(but I have a head start in knowing how to slow it up)
Thanks again.
Art Leong 2095 SS
