Old 08-13-2008, 12:51 PM   #1
Woodro Josey
Liked 3 Times in 1 Post
Default Auxiliary Fuel Tank
Do any of you guys know the best place to purchase an Auxiliary fuel (GAS) tank to go in the back of my Dually? Thanks for any info!
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
Old 08-13-2008, 01:10 PM   #2
Trevor
Guest
Posts: n/a
Default Re: Auxiliary Fuel Tank
Dont if it is the best place but I have seen them at Tractor Supply and the prices did not seem to bad
Old 08-13-2008, 01:24 PM   #3
bobby
bobby's Avatar
bought mine at Northern Tools a couple of years ago. Got the L-shaped one, 50 gallons. Think I paid around $500 for it. Aluminum thread plate. have it mounted on the back of my C4500. Beats having to stop every 200 miles to fill up the stock 25 gallon tank all the time. I don't use it unless I'm going on a long trip. Scared of the thiefs.
bobby is offline   Reply With Quote
Old 08-13-2008, 01:26 PM   #4
Woodro Josey
Bobby, do you have Diesel Fuel in yours or gas. They say not to use gas in theirs! Don't know why!
Old 08-13-2008, 02:22 PM   #5
Troy Henderson
Troy Henderson's Avatar
Liked 130 Times in 42 Posts
Here's where I got mine. Very good pricing for an aluminum tank. I hooked it up with their install kit that ties into the fuel neck. Not sure on gas use thought?
http://www2.northerntool.com/category/106+771279.htm
Troy Henderson
Henderson Race Shop LLC 816-520-5389
www.hendersonraceshop.com
Troy Henderson is offline   Reply With Quote
Old 08-13-2008, 02:41 PM   #6
Casey Miles
Liked 508 Times in 92 Posts
Woodro, I left a message at your house, my ex-girl friend has a 10X17X60 aluminum tank that she wants to sell. Her phone number is 954-476-6169.
Casey Miles
248H
E/S becasue of 4 hp
Old 08-13-2008, 02:52 PM   #7
Bob Verwold
Bob Verwold's Avatar
I bought a 90 gal tank for my dually from pit pal. They said it was for diesel but would work for gas. It has been a life saver for me as trying to get a 44 ft trailer into a small gas station won't work........I did ck with the Ohio HP and was told any tank under 100 gal was OK. But tank had to be bolted down and marked as gas.....................Good Luck
The worst part is paying for 130 gal of high test at one time.
Bob Verwold is offline   Reply With Quote
Old 08-13-2008, 03:09 PM   #8
bobby
bobby's Avatar
Woodro, it's says diesel only. But my truck is a diesel.
http://www.northerntool.com/webapp/w...6751_200306751
This is the one that I got. It helps hooking up the gooseneck trailer. Can't see it from inside the truck.
Old 08-13-2008, 05:20 PM   #9
Bobby Brannon
Liked 104 Times in 35 Posts
http://attatank.com/atta/auxiliary_tanks.html
Good Luck
Bobby Brannon 4705 STK, SS
Bobby Brannon is offline   Reply With Quote
Old 08-13-2008, 05:58 PM   #10
STK1217
STK1217's Avatar
Liked 10 Times in 7 Posts
Woodro i have a 150gl. saddle tank off of one of my big trucks that you are welcome to. it measures 24in.x 24in.x66in. If you are intrested contact me @ SST1225@verizon.net Im located 2hr. south of Reading PA. in Delaware. Thanks Mario.
STK1217 is offline   Reply With Quote
