Old 08-15-2008, 12:30 PM   #11
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Default Re: Cleaning a Body
Thanks everybody for the info.
John -
I appreciate your nuts and bolts perspective. I did find a place in Jackson, MS and a place in Ball, LA that do chemical stripping, but I cannot justify all the cost for this project. I am now gathering up materials to do a rudimentary rotisserie and plan on doing this by hand. I probably will do soda blasting after the undercoating and sound deadener are removed.
I have also done a few cars in my time, but this one has an unusually thick layer of undercoating and I was just looking for a easy way out.
Old 08-15-2008, 12:44 PM   #12
STK4340
For undercoating removal, I use a wirewheel on an angle grinder. It does take a little while but, I found it faster than Duzac's method. You will get dirty though. I used four large pipe jack stands to lift the car about 3' or so off of the ground to where I could sit and work under it. I too was too cheap for a rotisserie. Have fun. BTW, my Duster's factory undercoating was almost 1/4" thick in some places.
Ryan Becnel
STK4340 is offline   Reply With Quote
Old 08-15-2008, 02:27 PM   #13
Ken Haase
Dwight, the method John Duzac described works well, albeit a little messy. My suggestion would be to get a drywall compound spreading knife for the larger flat areas. I started with oven cleaner after the big chunks were removed from my Malibu's underside. Then finished up with Super Clean, a good rinse, and final wipe down with cheap lacquer thinner.
If you do go the soda blast route, I believe you have to neutralize with white vinegar if bare metal is exposed.
Should be a piece of cake using a rotisserie. Good luck!
Ken Haase is offline   Reply With Quote
Old 08-15-2008, 03:51 PM   #14
SSDiv6
John -
Here you go Dwight...an alternate method...
Old 08-15-2008, 05:44 PM   #15
Dwight Southerland
Wow! I thought I had an original idea!!
Old 08-15-2008, 05:47 PM   #16
Dwight Southerland
My rotisserie may be wooden circles cut from sheets of 3/4" plywood bolted to the bumper mounts on the car. Not exactly a rotisserie, but at least you can roll it over.
Old 08-15-2008, 08:10 PM   #17
John Duzac
John Duzac's Avatar
Liked 83 Times in 20 Posts
Smile Re: Cleaning a Body
Dwight: I saw the picture of the gut welding under the turck and in my wildest days would not get undet that truck! But I gotta tell you, this guy has a lot of nuts, or another way of saying it is nuts... Any way you choose to remove undercoating, the end result depends on the amount effort you put into the project. Spending alittle more time in the hard to get at areas will pay off when someone looks under the car. I call it pride... Good luck.
John Duzac D/S 4448 STK
John Duzac is offline   Reply With Quote
Old 08-15-2008, 09:46 PM   #18
RJ
What are you building Dwight?
RJ is offline   Reply With Quote
Old 08-15-2008, 11:53 PM   #19
House of Darts
Liked 20 Times in 15 Posts
I sell an American made tool that is specifically designed to remove undercoating. After doing several cars with a torch and steel wool and solvent, this is the best solution. The specialized wheel has done 3 cars and still works well. It will also take off paint although it isn't 100%.
House of Darts is offline   Reply With Quote
Old 08-16-2008, 12:18 PM   #20
Dwight Southerland
A rotisserie.
