Liked 3 Times in 2 Posts
I have my car finished, and am strugling to get the engine to perform as it should. Or maybe I am asking too much from it. A short rundown of the car..
90 Mustang, mini tubbed, 28x10.5's, 3.73 gears, coil overs, adjustable rear suspention, full cage, tubular front end with adjustable coil over struts. Car wieghs in at 2850#. I am currently running a c-4 trans built with all the good stuff, and a 4800 BTE converter. Motor is a 306 with KB hyperutectic 9.5:1's canfield aluminum heads, CNC ported 2.05/1.6 valves, parker funnel web intake, 750 carb, Stock block, Stock rods, stock crank. I use a MSD distributor, and a 6al box. The engine currently has a mid 500 lift hydrolic roller in it. I have seen Stock and Super Stock cars with stock heads, cams run faster than I am currently going. Car has been a best of 11.96 @ 119mph What do I need to do to get the car to go 10.7's? According to one of them slide rule calculators, I am only making 300HP, I would have thought this motor would have been higher. Any Help would be greatly appreciated. Fred
NHRA: Comp 2200 - S/C 2201 NMRA 2012 Outlaw 10.5 #10 |
Liked 34 Times in 7 Posts
combination, combination,
what are your compromises? pump gas? do you KNOW what the real c.r. is? do you have the cam card? do you think that 3.73 is enough gear? big heads dont always make an engine email me, venjr@aol.com do you have the camshaft card? copy and paste it to the email |
#3 | |
Liked 163 Times in 53 Posts
Stephen Johnson #2162 Horace Johnson #2167 SS/D 427 Ford Fairlane NHRA-IHRA |
Liked 26 Times in 13 Posts
Definitely a problem with the short times based on 119MPH and only 11.96 ET. Like Stephen said, you should be in the low 11's with a 119 MPH speed, so the car is not leaving hard.
Stockers don't have "stock cams". They have stock LIFT cams but tons of duration. Stocker motors, especially small blocks, spin at very high RPMs. A stocker with a small block will likely be spinning well over 7000 RPM and probably would have a 5.00 or higher gear, and a converter stalling at 5800+. Those are the things that make the car leave. Your MPH/weight number says you are making about 375 HP. You are going to be hard pressed to spin it as hard as you will need to do to make more power without getting rid of those stock rods. Making a stocker run quick ET's is NOT easy (or cheap), even if it looks like it should be. Get out your checkbook!!
Bill Harris ex 2172 STK ex 2272 S/S |
Found one of the time slips, 1.68@60', 7.75 - 89.56 mph @ 1/8, and 11.98@119.29 1/4
The car did leave kinda soft, I figured I still ad some adjusting to do there. It didnt feel like it spun the tires, I was thinking the 3.73 gear may be off, might need a 4.30, or so, shifted at 5800, and went thru the top end at 5750. Friend of mine told me I did not want to twist a Hydrolic Roller motor past 6400. I found the cam specs as well here they are. Crane Cams #449661 Part Number: 449661 Grind Number: HR-224/339-12 Engine Identification: Start Yr. End Yr. Make Cyl Description 1985 1995 FORD-MERCURY 8 Good mid range and upper RPM torque and HP, fair idle, performance usage, B303 upgrade, X303 replacement, bracket racing, auto trans with 2500+ converter, 3000-3400 cruise RPM, 9.5 to 10.75 compression ratio advised. Engine Size Configuration 302 C.I. V Valve Setting: Intake .000 Exhaust .000 HOT Lift: Intake @Cam 339 @Valve 542 All Lifts are based on zero lash and theoretical rocker arm ratios. Exhaust @ Cam 339 @Valve 542 Rocker Arm Ratio 1.60 Cam Timing: TAPPET @.004 Lift: Opens Closes ADV Duration Intake 32.0 BTDC 74.0 ABDC 286.0 ° Exhaust 76.0 BBDC 30.0 ATDC 286.0 ° Spring Requirements: Triple Dual Outer Inner Part Number 96870 Loads Closed 134 LBS @ 1.900 or 1 29/32 Open 358 LBS @ 1.380 Recommended RPM range with matching components Minimum RPM 2200 Maximum RPM 6000 Valve Float 6600 Cam Timing: TAPPET @.050 Lift: Opens Closes Max Lift Duration Intake 5.0 BTDC 39.0 ABDC 107 224.0 ° Exhaust 49.0 BBDC (5.0) BTDC 117 224.0 °
Liked 70 Times in 29 Posts
I think your heads are way too big for the RPM's you are running. They sound like they are for a 7500 RPM engine to me.
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
You are definatly soft when it comes to the first 1/2 of the track, 60 foots pretty weak, but picking up 30 mph in the second half is unusually high, esp for a high 11 second automatic car. 3.73 gears with 28" slicks is pretty mild, cams fairly mild too,. agree with the others, your heads seem more suited to a higher revving combination with more cam, compression, convertor and gear than what you curently have. As for the hyd roller lifters, I doubt that you will find many 5.0 Mustang Stockers that don`t exeed 6400 rpm all the time.
Liked 1,943 Times in 584 Posts
Freddie
If your car is for the track only you will need a 5.43 gear with the tire that you are using. The 373 is a stock ratio in the mustang GT. It is a highway and around town setup. Typically race and street do not mix very well. If you choose to run less gear then you will sacrifice performance.
Mike Pearson 2485 SS |
Thank You to everyone.
I am going to run the car as it sits for the last three races of this year, only because even though its slow its deadly consistant. I am working on a 360" bottom end that will have H-beam rods, and at least 12:1's in it. I have already picked up a .710 mechanical roller, with the matching springs and everything to put it in. I guess next I will get looking at gears. I mainly want to run S/ST with the car till I get my S/C Altered finished. then I may look at trying to get the lil stang into a SS class thinking one of the Modified's like G or F/M, the only thing I really need to change on the car is the front K-Member take the QA-1 unit out and put a stock one back in.
You can't run SS/GM with a V8 engine.
In SS/FM with a 360" engine, the car would have to weigh over 4500#. Most of the cars in that class run 280 cube motors. A 1990 Mustang with a 360" engine would probably best run SS/BM at 3060#.
| Thread Tools | |
| Display Modes | |
