Old 08-21-2008, 04:03 PM   #111
Smitty
Smitty's Avatar
Default Re: GT/AA Class War At Indy
My money is on the Cavalier from Norway, SC!!!! Guiluis Power, wish I could afford some!
Smitty is offline   Reply With Quote
Old 08-22-2008, 10:35 AM   #112
Mike Pearson
Mike Pearson's Avatar
Liked 1,955 Times in 590 Posts
Smitty,
The combination that Johnny and Andy have been running has been hit hard by the AHFS. They are giving up alot to the 400 cu in engine. Bigger motor Less factored HP you do the math
Mike Pearson 2485 SS
Old 08-22-2008, 02:17 PM   #113
Smitty
Smitty's Avatar
Smitty,
I see that major damage has been done to it but I got a gut feeling that they have some left, that's a pretty stout car. Remember they ran 9.0's two years ago with that thing, I gotta believe that Guiluis has found a few ponies in 2 years even with the HP hit.
Old 08-22-2008, 03:37 PM   #114
Shaun LeBlanc
Next year will be Fun!
Shaun LeBlanc is offline   Reply With Quote
Old 08-22-2008, 04:28 PM   #115
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
Hemi S/S heads and blocks: Lynn, I do not know what you have looked at, but I have a set of NEW Mopar stock hemi heads sitting on the bench and they look just like the 68 heads next to them. After they are finished they may not look the same, but have you seen a S/S small block or LS prepped legel head, they do not look much the same either. The newer hemi blocks add an additonal 60 pounds to the front of the car. If you deck a new hemi block much more than .350, you end up with a very thin deck which can crack and not seal. The stuff the SS/AH guys are running are nothing like the hemi prostock stuff. Dyno
Old 08-23-2008, 05:07 PM   #116
Lynn A McCarty
Lynn A McCarty's Avatar
Dyno you gotta look a little deeper. The old stock heads weighed like 58 lbs, I think is the number (getting old CRS), the new heads are substantially heavier like 72 lbs. That extra cast iron is in the porting areas.
What is the old axiom for porting? It is hard to port where there is water.
Lynn A McCarty 3470 SS
Lynn A McCarty is offline   Reply With Quote
Old 08-23-2008, 05:46 PM   #117
Lynn A McCarty
Moser Engineering is sending me an award coupon for the winner of GTAA. In the name of the late Greg Moser and www.DYAinc.org, they are awarding an axle and bearing package. I worked with Greg in 2002 to develop an affordable light weight axle and center section package priced for Sportsmen racers.
Any racer that purchases a Moser product from me will get a good price and all proceeds from the dealer portion goes to help take kids to a drag race. See us at Indy.
lmc3470@aol.com
317-839-8378
Old 08-23-2008, 07:49 PM   #118
Bench Racer
Liked 99 Times in 21 Posts
I got to agree with Smitty, Johnny and Andy Fogle are two of the hardest working Superstock Guys out there. They have flogged the 350/295hp combo to death and I don't think they can be outrun by another 350/295. That combo Has been horsepowered pretty bad over the last couple of years, but I think they have pretty well maxed out the potential of the engine. If you beat them for class you better have your "stuff" pack tightly in one sock, and you have something to brag about. If you out qualify them or beat them for class with the same engine, you have worked a miracle!! Don Jackson
Bench Racer is offline   Reply With Quote
Old 08-24-2008, 09:26 AM   #119
thomas sheehan
thomas sheehan's Avatar
Liked 75 Times in 29 Posts
GTAA update (from Cecil County).....
Bo Kenney hooked and went a 9.17 in round one of SS.
Air was around 2000 feet.
(82 degrees 58 hum 29.86 baro).
Good luck to all competitors at INDY (in all classes).
Tom
Old 08-24-2008, 02:01 PM   #120
John Mason
My money's on Grossi. Killer combo.
John Mason 7743 SS
John Mason is offline   Reply With Quote
