Old 08-28-2008, 03:14 PM   #11
Jeremy
Default Re: Fiberglass Leaf Springs w/ cal tracs?
Make sure Cal Trac know your using the fiberglass springs when you order as the length of the bars will be slightly different.
Thanks Jerry
Jeremy is offline   Reply With Quote
Old 08-30-2008, 01:06 AM   #12
junior barns
Liked 20 Times in 14 Posts
Anyone run this on a stick car?
junior barns is offline   Reply With Quote
Old 08-31-2008, 12:14 PM   #13
67camaroracer
67camaroracer's Avatar
Thanks Jerry
I have already turned the bars back as they were too long. I didn't run into this problem until after installing the fiberglass springs. I was running the stock and then the calvert split springs before with no problems
67camaroracer is offline   Reply With Quote
