Old 09-27-2008, 11:19 PM   #1
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Default motorcraft 4300 carb info
any one running a motorcraft 4300 carb,looking for some on set up any info would be helpful,tom thanks for you info thanks gmonde
Old 09-29-2008, 04:57 PM   #2
Duane Eiskant II
Duane Eiskant II's Avatar
Liked 57 Times in 33 Posts
Default Re: motorcraft 4300 carb info
i run the 4300D on my combo love it. back to back with dads 780 holley off his 71 runs the same..
Duane Eiskant
1354 Stock/Super Stock
Duane Eiskant II is offline   Reply With Quote
Old 09-29-2008, 07:39 PM   #3
Chris1529
Liked 70 Times in 29 Posts
what CFM is the motorcraft Duane?
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 09-30-2008, 12:24 PM   #4
Duane Eiskant II
on the wet flow bench at work its a hole 580
Duane Eiskant
Old 09-30-2008, 06:31 PM   #5
Jeff Lee
Jeff Lee's Avatar
To clarify, the 4300 Autolite is different from the 4300D Autolite in that the D series is a spreadbore with larger throttle blades than the 4300 "non D", correct? I believe the 4300D was rated at about 715CFM. Correct me if you have other info (I run the 4300 non-spreadbore).
And I probably should not reference this as a "spread-bore". Square flange or spread-bore flange may be more accurate.
Jeff Lee 7494 D/S '70 AMX
Old 09-30-2008, 07:12 PM   #6
FED 387
Liked 333 Times in 180 Posts
Exclamation Re: motorcraft 4300 carb info
According to a buddy of mine these are the specs for both carbs
4300 Carb depending on the particular model these measurements can vary from
441-605 CFM
Venturi 1-1 1/4 in primary
Bore 1 7/16 P--- 1 9/16 S
1 9/16 P-- -1 11/16 S
4300D carb
715 CFM
Venturi 1 1/4 P
Bore 1 9/16 P--2 S
This carb (4300D) is ONLY on 71 Boss 351 Cleveland & 72-74 351 Cleveland engines ---4300D carb will only fit a specific manifold -- Not interchangable with a 4300 manifold WITHOUT an adapter!!!
Comp 387
Old 09-30-2008, 07:40 PM   #7
gmonde
gmonde's Avatar
jeff we do run a spread bore (not much of one ) but it is a square flange bolt pattern
1 9/16 P-- -1 11/16 S and a 605 cfm "man talk about a choke " gmonde
Old 09-30-2008, 08:05 PM   #8
FED 387
605 CFM carb came on the 1971 351 cleveland engines NOT the BOSS engines those were 4300D==Comp387
Old 09-30-2008, 09:51 PM   #9
dwydendorf
dwydendorf's Avatar
Liked 19 Times in 7 Posts
The motorcraft and autolite carb with the square (not spreadbore ) baseplate is refered to as the 4300A. As far as I know there were basically two sizes of these carbs, a smaller version that came on the 68 302 and 69 351w engines and the bigger version that came on the 70-71 351c and 68-75 429-460's. I also heard that the AMC's had some of these carbs on their engines. I ran one on my 70 mustang in SS and it is very touchy carb to mess with, a real pain.
dwydendorf is offline   Reply With Quote
Old 09-30-2008, 10:18 PM   #10
FED 387
4300 carbs were rated @
441 cfm--67-68 J code engine
470 cfm -69 351W
595 cfm-69 390 S code engine
600 cfm-70 351 W & 351 C engine
605 cfm-71 351 C engine
715 cfm 71 Boss 351 C & 72-74 351 C engines--THIS IS THE 4300D CARB
