Old 10-01-2008, 01:54 PM   #1
Michigan Skip
Default IHRA class HP ratings
Where do I find the hp ratings for Stock/SuperStock? All I can find is the adjustments and nothing for my 95 LT1 I'm trying to make sense out of how to find what class I can run in with a 95 Camaro Z28 at roughly 3400#
Skip Willis
95 Z28
IHRA ST/666
Michigan Skip is offline   Reply With Quote
Old 10-01-2008, 02:03 PM   #2
GUMP
Liked 2,360 Times in 558 Posts
Default Re: IHRA class HP ratings
You probably need to check with the IHRA (send them an Email). The last time that I checked the HP for IHRA was 325. The IHRA is still running the fuel injected classes, so you would be in B or C. You would have to take out weight for B (8) and add weight for C (9) (class x HP+170).
GUMP is online now   Reply With Quote
Old 10-01-2008, 02:04 PM   #3
GUMP
I would ask for a different competition number too!
Old 10-01-2008, 05:03 PM   #4
Ed Wright
Ed Wright's Avatar
I don't know about Stock, but IHRA has the LT1 at 275 in Super Stock. It was like pulling teeth to find that out. Got one email back from te tech dept telling me they had not raised it last time NHRA did, not help much since I didn't know what it was before that. Had to go to a race to get an anwer. In Super Stock you will be in the bottom of SS/JA (3195 lbs min.) at 3400, add 70 lbs to run SS/KA, 3470 lbs minimum weight.
Ed Wright 4156 SS/JA
Old 10-01-2008, 06:46 PM   #5
Doug Blackley
Doug Blackley's Avatar
Unless IHRA listed an adjustment, they use the original factor from NHRA but not their refactor. Example the 85 305 150 hp combo is at 258 in NHRA and 250 in IHRA.
Doug Blackley 1697 STK
Old 10-02-2008, 11:13 AM   #6
Michigan Skip
Thanks guys.
It looks like IHRA lsets you decide what class you want by either multiplying your weight by the HP and then looking to see what class you fit. Or looking to we what class you want to run, and making the car fit the class.
On the NHRA site, for a 95 Camaro 4sp Auto, it looks like they give you only one choice (factored hp= 341, weight factor = 10.0) so according to the spreadsheet it calculates that weight needs to be 3289. I have the IHRA rule book and it gives a range of weight factor for each class (10.00-10.99) for instance, but I don't have the NHRA book. Does it give a range for each?
Thanks again.
Skip Willis
95 Z28
IHRA ST/666
Old 10-02-2008, 01:03 PM   #7
danny waters sr
danny waters sr's Avatar
Skip, My books show your car as a natural c/fi @ a 10.12 weight break and has a min weight of 3420# with driver .You may go up or down a class from your natural class break .B/FI would figure a 9.00 # weight break with 3095 # as min weight.D/FI would figure a 11.00 weight break with 3745# as min weight ..In IHRA you would have to run fuel injection classes only. These figures are fo a hard-top and not a convertible. Hope this helps ..I will be in New York next weekend working the IHRA div race if you would like to see this in our book ..Hope this helps .
Old 10-02-2008, 02:57 PM   #8
Bryan Worner
Liked 535 Times in 86 Posts
All you had to do was ask me Ed! It's been 275 in Super Stock since I started running the LT1 in 2002. It should still be that in Super Stock, not GT, in NHRA!!!
Bryan Worner is offline   Reply With Quote
