Old 10-04-2008, 02:35 PM   #1
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Talking water pump drive vs electric pump
does a electric water pump cool the engine better(meaning maintain a lower water temp.longer)than a water pump drive set up.
astikhossw is offline   Reply With Quote
Old 10-04-2008, 10:55 PM   #2
Dragsinger
Liked 99 Times in 60 Posts
Default Re: water pump drive vs electric pump
To me, the answer is yes, the electric is better. My reason being you have much more control with the electric pump. Example, you are finished the burnout and easing into the staging beams when the starter realizes the pair before you has not cleared the track. Because of a spill, you have to wait 10 minutes before running. With the electric pump you can easily bring the engine back to per-burnout temp. If you had an engine driven pump, you would not have that option.
By using an electric water pump with an electric fan and having separate switches for each, you can put the engine temp at the same place each run. Of course, consistent engine temp is one more tool toward a consistent running car.
Larry Woodfin 471W
Old 10-05-2008, 03:54 PM   #3
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
I took that question to mean an electric water pump versus an electrically driven pump (like the Moroso kits with the little cogged belt that drives an OE style water pump ). I am presently shopping for an electric pump and the specs (flow and amp draw) differ tremendously from brand to brand.
Tim H is online now   Reply With Quote
Old 10-05-2008, 04:58 PM   #4
Rob Petrie E395
Liked 216 Times in 77 Posts
One more thing to check is different flow rated pumps for the same application from the same manufactuer.
Example
chevrolet lt1 and I think there others
Meziere WP118 32 Gal per hour
Meziere Wp118HD 55 Gal per hour
Both of these pumps fit the same application and the price is only about 25 dollars higher for the 55 gal. I had the 32 but after about 6 years it started to have a strange sound to it so I replaced it with the 55 model. After a run I can have the car back to below 120 degrees in about 10 minutes or less where it used to take a bit longer with the 32 and was almost impossible to get it cooled down in time for the next round with a engine driven pump since there was no way to circulate water without the engine running.
Old 10-05-2008, 07:07 PM   #5
astikhossw
astikhossw's Avatar
Cool Re: water pump drive vs electric pump
Tim that is what i mean,a electric drive system vs a electric water pump.And does it cool better with the electric pump than the electric drive system.With my electric drive system after a run i am at about 220 f and i guess it takes about 15 are so minutes to cool back down to 140 f.
Old 10-06-2008, 11:11 AM   #6
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
220 wow! I have a high flow alum with an electric drive & it almost never gets above 160. But I have a 3 core rad too.
Old 10-06-2008, 03:52 PM   #7
John Lang
Liked 6 Times in 2 Posts
Smile Re: water pump drive vs electric pump
Do you gentlemen consider that when useing a pump such a Mezere, you also need an electric fan for pulling air through the radiator, which then your useing about double the amperage of a alum pump,w/fan blade, W/moroso elect motor w/belt drive! Just some thing to think about. I had a Mezere and that burned up, which i then switched back to the setup i had on the shelf...and saved money, for BEER. Later..... John
John Lang 365 STK, SS
John Lang is offline   Reply With Quote
Old 10-06-2008, 08:38 PM   #8
astikhossw
astikhossw's Avatar
greg would that be 160 at your pit area,i also have a aluminum griffin radiator and alum pump with a electric fan i turn the electric fan off during the run and turn it back on during the coast down.This is also a 14.1 motor.
Old 10-06-2008, 09:11 PM   #9
Chris1529
Liked 70 Times in 29 Posts
I run the moroso drive with a separate electric fan. I too turn the fan off during the run.
one note of caution, I have the allen head set screw tha holds the pulley on the shaft work loose, so the water pump quit spinning. With no water is getting to the temp probe, it was almost too late before I caught the problem!
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 10-07-2008, 08:12 PM   #10
greg fulk
greg fulk's Avatar
No that would be 160 @ the end of track! My car dosen't even read most of the time when I roll into the water box. I know alot of time by the time I get accross the scales my car is cool enough to make another pass!
