Thread Tools | Display Modes |
#11 |
To simplify it we burn Methanol and we drink ethanol.
#12 | |
Marc Caruso S/G 132 S/C C132 |
#13 |
Although now we mix ethanol with gasoline to make E85,so I wonder when the government will start charging the liquor tax on E85.
#14 |
Guest
Posts: n/a
I thought mouth wash would also give you a false reading for alchol.
#15 |
Liked 503 Times in 131 Posts
I sure hope they are careful with the info. Some medicines can make you have false positives....
Eric Merryfield 1883 STK |
#16 |
This may sound stupid, but what about mouth wash, cough meds., anything stupid like that? I know around here(Conn.) The joke is if you were to go through a D.U.I. stop and you just used mouthwash, you would fail the breath test. (not bad breath, drunk breath). I hope before the media gets this one and drags Scott's name through the mud, there is some kind of investigation as to what it exactly is!
#17 |
Liked 216 Times in 77 Posts
when this all came out a couple of weeks ago on dragracing online I asked my sister in law about this. She works for the state of Virginia crime lab and regularlly testifies in both drug and alcohol DUI cases. Basiclly what I understand now is if we have alcohol in our bodies when we die it turns into a ethanol type substance and by doing blood work and calculating the amounts of it in your blood they can determine how much you may have had to drink or what your blood alchol level might have been at the time of death. She went on to say as a example that if a cdl licened person such as myself were to go out and drink heavily the night before work and get in a truck wreck early the next morning it is likely I would show this kind of stuff in my system and If I survived the accident I would lose my cdl license in most states. My understanding is that while you may not appear or act drunk all of the effects even the next day are not completely out of your system. She tried to go on about a bunch of other stuff relating to how the body breaks down alcohol but to be honest alot of it was scientific crap that was way over my head and I would have trouble explaining it or I would.
#18 | |
However the higher the level of trauma….the higher the natural alcohol (Ethanol) level will be and can make it difficult to make and accurate assessment and that is what it makes it hard to prove in legal cases where the levels are tested post mortem. I think most will agree that the level of trauma in this case is off the charts. |
#19 |
called sister in law again. How they find out if the ethanol in a dead persons blood is from alcohol or from the bactiera in your blood breaking down after death is they take a sample of your eye fluid. Appearently the same things that happen with your blood do not happen the same with ocular (might be spelled wrong) fluid and therefore they can tell from that. The other key thing in Scotts deal is that they knew the exact time almost to the second of death so that makes it easier to calculate weather it is the alcohol or just the natural things that go on in the body after death because they know from extensive research how long it takes the bacteria in the blood to break down and make ethanol. Again she went into a bunch of scientific stuff she said there are sites on the net that go into this in detail look for a site about autopsies. I asked about the mouth wash deal too. She said she has testified in thousands of cases and has yet to see anyone conviced of dui because of good hygene. She said that yes if you used some mouth wash and then blew in a brethalizer right away you might get a reading it depends on the alcohol content of the mouth wash some nowdays dont have any. The reason you would not be convicted is because when you get a DUI they make you sit at the station for twenty minutes without belching burping ect. if you do the 20 minutes start over this is to make sure any alcohol in your mouth is gone and does not interfere with the 2nd breathalizer test at the police station. In VA both readings are admissable in court and if you jack around and try to keep burping and belching to get out of the test you dont get the second test and are usually convicted on the first test. Another thing about mouth wash is using a normal dose as directed what little alcohol is in it evaporates quickly during normal breathing unless you swallow it and even then there would not be enoughf to get a bac of .02 so his good hygene does not appear to have caused the reading unless he was chugging mouthwash during the day. I also asked about what would happen if you went out and got stinking drunk the night before. The body is capable of reducing the Blood Alcohol content between .01 and .02 per hour depending on liver function and some other factors therefore if at midnight you had a bac of .20 it would take at least 10 hours to get it all out of your system. She said that unfortunetly my hero had some alcohol in his system. Just so nobody thinks I am trying to slam Scott he was my favorite funny car driver and his death bothers me alot, but the sad truth appears to be that for some reason he had some alcohol in his system for some reason and I hope as well that the media doesnt at some point try and slamm a good man and father over something that most likely did not have a role in his death.
#20 | |
I'd be interested in seeing if anyone has ever done a study or test on alcohol absorption by people working on and/or driving any car that runs on any percentage of alcohol as a fuel. I'd be willing to bet inhaling the fumes alone will register on any available on-site measuring device. How methanol fume inhalation (burning or not) would register as ethanol in a human body during an autopsy would also be interesting to know. I honestly believe Scott having a BAC that low is a non-starter - it had nothing to do with his condition or the accident.. |
