Old 10-10-2008, 08:49 PM   #1
stock eliminator
Default new at this have question about engine blocks
I was wondering if you can bore out lifter holes and put in larger lifters and/ or put bushings in them. Question two can i put 4 bolt mains in a 2 bolt main block. Question three can i use a gridle on my mains to tie them all together. Question four can i use tubing to redirect the oil back to the oil pan. Question five can i use a windage tray. This is for a 1986 J/SA 305 Camaro NHRA rules thanks
stock eliminator is offline   Reply With Quote
Old 10-10-2008, 10:44 PM   #2
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Default Re: new at this have question about engine blocks
1. Bushings, yes. Larger diameter lifters, no.
2. Yes, but you won't need them on a 305 Chev.
3. See 2 above.
4. No
5. Yes
Old 10-11-2008, 04:34 AM   #3
stock eliminator
OK. Thanks for the info i really needed those answers. Forgot one can i put small tubing in lifter valley in those holes where oil drips down on cam and crankshaft. Or can i plug them. thanks again
Old 10-11-2008, 08:11 AM   #4
Dwight Southerland
Yes.
Going back to your first post, if you want to build a strong base for a 305, start with a 350 4-bolt block and sleeve it back to 305 bore size. That work is no more expensive than adding 4-bolt caps and a girdle to a 2-bolt block and will benefit this combination much more than all the crank containment work. When was the last time you heard someone spitting a crank out of a SBC Stocker? When was the last time you heard someone complain about ring seal in a SBC stocker? 'Nuff said.
Old 10-11-2008, 08:54 AM   #5
Jim Cassels
Dwight,
Six or seven yrs. ago I did the 350 4 bolt sleeved 305. After all the work was done on the block I was told by NHRA that was not legal. My question, is this a legal modification now. I think I got 2 cases of beer for it?
Jim
Jim Cassels is offline   Reply With Quote
Old 10-11-2008, 09:43 AM   #6
BRUCE PARSONS
Banned
Buy a small bore bow-tie block. You will still have it when you're ready to quit!
BRUCE PARSONS is offline   Reply With Quote
Old 10-11-2008, 11:56 AM   #7
Dwight Southerland
I assumed that it was legal since there are so many sleeved 454s masquerading as 396s. Seems like last year in discussion the 4-bolt is not legal for the 305.
Bruce, you are exactly right!!
Old 10-12-2008, 09:04 PM   #8
stock eliminator
Well i want to thank everyone for all the info. And i know everything i asked is overkill. But that's who i am. I will do a 200 percent effort to be the best. I'm just that way. thanks again
Old 10-12-2008, 09:09 PM   #9
NovaMan
NovaMan's Avatar
While we're on the subject, is there really much to be gained by indexing the lifter bores on a small block Chevy? I thought they were pretty darn close to right-on from GM.
~Pete
1970 Nova
NovaMan is offline   Reply With Quote
Old 10-12-2008, 09:53 PM   #10
Jeff Lee
Jeff Lee's Avatar
I'm no expert on chevys but I'm under the impression the exact opposite is true.
Jeff Lee 7494 D/S '70 AMX
