Old 10-14-2008, 03:53 PM   #11
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
Default Re: underhood working on the 93 up Camaro/Firebird
For engine install on a stock LT-1......I made a spreader bar and attached 4 chains to it and bolted them to the 4 corner exhaust holes on the heads. Attached the bar to my engine hoist as tight as possible to the top of manifold. Nothing on the front of the engine and radiator/shroud out. No water pump, distributer or balancer Engine just squeezes in and I did not remove the hood.....just remove the strut clips and stand the hood up with a broom handle. Sparkplug access was pretty bad on #5 and I made a wrench to fit. It was easier to get it out from underneath with Hedman stepped headers. I removed steering box mounting bolts on drivers side to get header on easier and not scratch up the coating. I replaced valve springs on the car. Front half of engine is easy, rear half is a little tougher. An old style spring compressor works mint for the back cylinders and a lever type works fine on the front ones. The old one I think was a K-D item and is a clamp type with legs that hook the bottom of the spring. It has a wheel and screw arrangement that you use to compress the spring. Works good for small diameter stock type springs. Under the hood is not that bad..... interior work and under the dash is torture. Jacking it up is a chore also with the long nose.......Nice cars that work well and are fun to drive. If I had a lift available for working on mine it would have made working on it a lot easier and I might have kept it........
Rich Biebel
S/C 1479
Stock 147R
Rich Biebel is online now   Reply With Quote
Old 10-14-2008, 07:28 PM   #12
Michigan Skip
Rich, that is why I got one of these.
http://kwiklift.com/
Solved a LOT of problems for me.
Skip Willis
95 Z28
IHRA ST/666
Michigan Skip is offline   Reply With Quote
Old 10-15-2008, 02:31 PM   #13
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
I changed the LT1 in my stocker with the "happy hooker". Works great, uses the bolts that hold the fuel rails down, looks scary because of the small bolts, but I never dropped one. If you use a swivel off of the engine picker, it is easier to turn the engine around to get it in. To change a LS1 engine, it was more difficult because of the composite (plastic) intake, the intake would have to be bolted on after the engine was installed. Myron Cottrell from the Horsepower Farm in Chaska, MN makes and sells them. Check out the web site www.tpis.com or call Bob at 952-448-5330. Sells for $40.00. Dyno
Old 10-15-2008, 06:35 PM   #14
TOSTO RACING
TOSTO RACING's Avatar
Liked 664 Times in 187 Posts
I just use the regular old engine hoist on the ls cars and it comes right out of the top. They aren't really that bad to work on once you get all the crap out of the way that you don't need.
5664 GHI/SA
1985 CAMARO RED H/SA
1985 CAMARO BLUE I/SA
TOSTO RACING is online now   Reply With Quote
