Old 10-19-2008, 10:51 PM   #1
Whalen3186
Liked 109 Times in 32 Posts
Default Possible converter problem
I think I may have a converter problem and would like to hear what everyone else thinks. I bracket raced the car today and the 60 ft times were all over the board. The first pass was the best at 1.50 then second pass it went 1.56, then 1.51 and back to 1.56 or 7. Passes 1 and 4 were in the same lane and 2 and 3 were in the other lane. The car felt really sluggish on the two slower passes, almost like I was just spinning but dad was watching and said that wasn't the case. Plus everyone else I talked to didn't seem to be having much of a problem hooking up. The tires were brand new last weekend, Hoosier radials. The car is an 85 Camaro, 305 launching at about 2900 with a 2-step. Its an ATI converter but I'm not sure what it is set at. Thanks for the help.
Whalen3186 is offline   Reply With Quote
Old 10-20-2008, 06:43 AM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Possible converter problem
Some times the sprag or the roller clutch that locks the stator will slip. This will cause the converter, to not consistently multiply torque. If you have a data logger, you might see a lower stall speed, or during a shift the fall back rpm would be lower.
Old 10-20-2008, 07:33 AM   #3
Ultimate Converter Concepts
Sponsor
Ultimate Converter Concepts's Avatar
Liked 59 Times in 12 Posts
This is true, a worn sprag or roller and spring problem will allow the stator to slip and act erratic. This will effect your 60's and overall ET. This will usually continue until the sprag assem fails and you have no torque multiplication at all.
Lenny@UltimateTC
Lenny Croteau
www.ultimateconverter.com
Phone 704-892-6837
Ultimate Converter Concepts is offline   Reply With Quote
