Old 10-20-2008, 09:52 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default 82 - 92 Camaro front struts and springs
Let me hear what front strut and springs are being run for a 3rd gen F body stocker. Specifically, a 1990 Firebird in IHRA Crate Motor, SBC weighing about 3050 with driver.
Thanks
Larry Woodfin 471W
Old 10-20-2008, 10:08 PM   #2
SSDiv6
Liked 1,603 Times in 583 Posts
Default Re: 82 - 92 Camaro front struts and springs
Thanks
Do a search on this Forum...it has been discussed many times...
http://classracer.com/classforum/showthread.php?t=13169
http://classracer.com/classforum/showthread.php?t=7884
http://classracer.com/classforum/showthread.php?t=10392
Old 10-20-2008, 10:38 PM   #3
Dragsinger
Since I am not on a tight budget and generally buy upper end parts, those links did not help me. Still open to hearing from other racers.
Thanks
Larry Woodfin 471W
Old 10-20-2008, 10:49 PM   #4
Jim Cimarolli
Liked 166 Times in 46 Posts
Smile Re: 82 - 92 Camaro front struts and springs
True Choice if you want double adjustable struts. Or, Koni if you want single adjust. If you do the True Choice be sure you request that you want them as loose as possible on the extension. Their struts are a modified Koni. I built a '91 Camaro for a customer, we started off with the Koni's, then sent them in to True Choice to be modified. When we got them back they were too tight at the loosest setting on the extension, had to send them back to be changed. I think I would try the Koni's, then if you have to have more resistence on the compression you can send them to True Choice to be changed to double adjust.
Jim Cimarolli is offline   Reply With Quote
Old 10-20-2008, 11:24 PM   #5
Tommy Gaynor
Tommy Gaynor's Avatar
Liked 5 Times in 3 Posts
I agree I raced an 85 Camaro for 3 years and the konis rocked.
"Go With Confidence"
Tommy Gaynor is offline   Reply With Quote
Old 10-21-2008, 12:03 AM   #6
J DeForrest
J DeForrest's Avatar
Liked 73 Times in 18 Posts
Thumbs up Re: 82 - 92 Camaro front struts and springs
I switched over from some old Koni singl adj to Vari-Shock Dbl adj. a couple months ago. Difference was night and day. The range of adjustment is right where ot needs to be in my opinion. I had to replace the upper mount bearing, but I am very happy with being able to make a quick adjustment to conditions and can tell a change was made.
Jason
J DeForrest is offline   Reply With Quote
Old 10-21-2008, 09:53 AM   #7
SSDiv6
Thanks
Since budget is not a concern, here you go:
http://www.santhuffshocks.com/struts.html
Old 10-21-2008, 11:55 AM   #8
Dragsinger
The Santhuff parts are not legal for my application. The stockers, [including IHRA Crate Motor classes] must run the OE spring and strut configuration.
Larry Woodfin 471W
