Old 10-31-2008, 08:17 PM   #11
rgarvey
Default Re: Super Stock DQ in Vegas
Originally Posted by Jim Cimarolli View Post
Good for Gregg! This fuel check bs is getting out of hand!!
Every time I have gone through fuel check this year with C-12 they give me the pucker faced look.
i agree with the fuel check how bogus can this fuel really be? even when vp is the official fuel of nhra. ive had all kinds of issues with vp c12. i like the fuel it works good but if it does not pass its no good to me . thats why i switched and have not had any problems since. and it is cheaper and runs the same.
rgarvey is offline   Reply With Quote
Old 10-31-2008, 09:59 PM   #12
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
I`ve never had a problem with Sunoco Purple,even after sitting in the tank all winter.
Lane Weber
Old 10-31-2008, 10:17 PM   #13
Liked 1,880 Times in 422 Posts
We have had some very slight issues with C-12. Neither car has been tossed, but we have been told it read marginal. Normally, adding some fresh C-12 resolves the issue. Each time it has happened we've been told that it has gone somewhat "stale" from being exposed to the atmosphere (in a vented fuel cell between races mostly). We now usually drain both cells down to about what we need to load the cars and unload them later. Then we just add fresh C-12 before time trials. I guess C-12 is somewhat sensitive. But I like the results I get with it, so long as I don't have worse issues, or need more octane, we'll stick with it.
Old 10-31-2008, 10:35 PM   #14
BLAZER
Liked 7 Times in 5 Posts
Has anyone ever smelled bad gas?
BLAZER is offline   Reply With Quote
Old 10-31-2008, 10:57 PM   #15
Charlie Ford
We've had several "situations" where our fuel didn't check. We run C-12. In each deal, I questioned the validity of the "checking" process. In one incident, 2 cars, same fuel, same jug, one is good, one wasn't. In the one that didn't check, after a confrontation, we took the jug for checking. We were told that the fuel in the jug was OK. We were told to drain the fuel in the car, "flush" the system, then refuel the car with the fuel out of the jug. We proceeded to do nothing. In fact I sat at the trailer and had a "cold one". About an hour later, we took the car back to fuel check, and it passed with flying colors!! On other "failures" I've been given all kinds of scenarios. Fuel is old, fuel left in jugs, fuel left in trailer, fuel left in car, etc,!!!! This year I asked the tech guys to check some fuel that had been IN THE FUEL CELL of one car that hadn't been run for 14 months. It checked good!!! So much for theories!!
Charlie Ford 4729 STK
Charlie Ford is offline   Reply With Quote
Old 10-31-2008, 11:09 PM   #16
bill dedman
Liked 6 Times in 4 Posts
Default Re: Has anyone ever smelled bad gas? asks Bwheat
No, Buffalowheat; tell us about it.
Is that your hobby?
Bill
bill dedman is offline   Reply With Quote
Old 10-31-2008, 11:12 PM   #17
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Same here.
Old 11-01-2008, 12:37 AM   #18
Mike Voth
Mike Voth's Avatar
Liked 57 Times in 14 Posts
With regard to the people who have already replied to this thread: What engines do you guys run? I know the C-11 is better than C-12 for our small block (more power on dyno), and it burns cleaner. Never have had a problem with C-11, and we start the year with what's left in the trailer. It usually sits awhile and goes through the winter outside.
Mike Voth
5189 GTN - 5188 GTO
Voth Racing
Mike Voth is offline   Reply With Quote
Old 11-01-2008, 09:36 AM   #19
Bryan Worner
Liked 535 Times in 86 Posts
Byron, Dad and I all run Sunoco purple. I only remember 1 time we had an issue and that was Dad at E'town this year........but Byron and I both passed!!! Same fuel, same drum! You figure that one out???? They blamed it on the car???
Bryan Worner is offline   Reply With Quote
Old 11-01-2008, 10:59 AM   #20
Bobby Brannon
Liked 104 Times in 35 Posts
Shreveport Points meet last month after 2nd round stock.I pulled C-12.. Gave to fuel check, it FAILED.. Go back and get another it Failed. Waited for about 12 racers to go thru.. 3rd time C-12 PASSED with flying Colors.. Go figure
Bobby Brannon 4705 STK, SS
Bobby Brannon is offline   Reply With Quote
