Old 05-08-2007, 01:43 PM   #1
Joe Grippo
Liked 41 Times in 4 Posts
Default Question for the big wheelstand guys
Question for the big wheelstand guys?Other than a normal nut and bolt examination and a suspension check, what other types of things do you look at on a regular basis? I have been hanging the wheels pretty high recently and I don?t want to overlook anything during my weekly maintenance. I have been looking at ball joints, upper and lower a-arms, engine and accessory bolts etc. Any other suggestions?
Wanna see some pictures?
http://public.fotki.com/JoeGrippo/
Joe Grippo is offline   Reply With Quote
Old 05-08-2007, 01:55 PM   #2
Stephen J
Default
Wheels, we bent a set a couple of years ago.
Stephen Johnson #2162
Horace Johnson #2167
Ex-Jim Van Cleve
Stephen 2162
Horace2167
Stephen J is offline   Reply With Quote
Old 05-08-2007, 05:30 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
Default
Make sure your snubbers are up to par, When I started getting big air this year ,I put a set of heavy duty urethane snubbers on the control arms. .... keep an eye on the front shocks too. ... They don't like getting bottomed out. ..... Tom
Old 05-08-2007, 06:33 PM   #4
LILWJ
Guest
Posts: n/a
Default
ON My Firebird it was bad about tearing the inner fenderwells out when it came down, so i cut the very tops of them out and it stopped that problem, but it is also bad on front end alignment by coming down so hard, need to keep the compression on the shocks pretty stiff and of coarse the wheelie bars have saved my mutt quite a few times and even with them sometimes it is pretty violate!
woodro josey
I miss Buster Couch and Lex Dudas.
Old 05-08-2007, 07:28 PM   #5
Tim Barrett
Liked 472 Times in 72 Posts
Default
If I can ask,,What have you guys done to help yank the wheels up higher?? A few years ago if a Stocker could get the tires off the ground they were doing great. Now it seems that alot or most of the guys are in need of wheelie bars. I can get mine about a foot in the air but thats it. Most of the time less. But my suspension isnt very fancy. Moroso front springs with Lakewood 90-10 and the back are multi-leaf with lakewood traction bars and Comp. engineering rear. Got any ideas on changes for me?? Tim Barrett H/SA 1925
Tim Barrett is offline   Reply With Quote
Old 05-08-2007, 09:23 PM   #6
Brian Holcombe
Default
Tim,
what kind of car do you have?
how quick do you 60ft now?
Brian Holcombe is offline   Reply With Quote
Old 05-08-2007, 10:34 PM   #7
Geerhead55
Liked 5 Times in 5 Posts
Default
Brian,,, Tim has a 69 Camaro. You can see the car launching on Autoimagery.com.
Danny Durham
Old 05-09-2007, 12:02 AM   #8
Bruce Fulper
Liked 54 Times in 33 Posts
Default
hahaha...I GOT to see that "vair getting "big air." !
I love your car - don't get me wrong. but "big air"?
I miss step.
Bruce Fulper is offline   Reply With Quote
Old 05-09-2007, 05:12 PM   #9
Tom Goldman
Default
You missed the Man after the Gold., not Gould. .... I'd like to see Tom's Corvair get some air!. .... Tom Goldman
Old 05-09-2007, 06:04 PM   #10
Chris Hill
Liked 244 Times in 26 Posts
Default
"If I can ask,,What have you guys done to help yank the wheels up higher?? "
I don't mean to be fllipant with my response, but just simply more hp being applied to the ground is causing the big wheelstands.
It seems on a stocker, once your et dips into the 10 second range, the ability for the big wheelstand is possible. It is the car trying to accelerate that causes the wheelstand. If you bolted the rear tires to the ground, i don't think you could lift the front wheels off the ground (it's been a long time since I calculated it).
On our 'cuda, we were breaking in a new engine in March at Bowling Greene, Ky. The previous year it was running roughly low 11's at the time. The first time I made a real pass in the car, it got so high I had the sensation of falling over backwards in a chair and luckly shifted from 1st to 3rd to bring it down without crashing it. This was way before stockers were allowed wheelie bars. We changed the front shocks and did not have any issues after that. The car would've went roughly a 10.80 pass if I remember correctly.
Chris Hill
Spec 125 Light
Chris Hill
