Old 11-03-2008, 11:46 PM   #11
SSDiv6
Default Re: Engine "Braking".......Does it hurt the motor ???
Originally Posted by trmnatr View Post
See post #6, What about a small block that run 8,100-8,400rpm past the lights with aluminum rods and a TH400 automatic that is a transbrake so it is a reverse valve body so you cant put it in Neutral
Use a Precision Performance Products Kwik-Shift-1, ProHydro shifter with the safety neutral shifter
(P/N 408) The shift pattern is P N/R 1 2 3 N, reverse is neutral position with trans-brake engaged.
http://www.precisionperformance.com/power1.htm
http://www.precisionperformance.com/faq.htm#faq8
Old 11-04-2008, 01:02 AM   #12
trmnatr
Is there too much engine braking with a transbrake that doesnt use a front band? Would that sort of transbrake do any harm? Its a Hughes/JW style and doesnt use a front band
trmnatr is offline   Reply With Quote
Old 11-04-2008, 01:38 AM   #13
Real Racer
If engine braking is suposed to be so bad, I wonder what kind of damage all of the top end womp womping is doing?
Real Racer is offline   Reply With Quote
Old 11-04-2008, 11:45 AM   #14
Chris Hill
Liked 244 Times in 26 Posts
I think the main issue is making sure the oil sump stays covered during decel is the main issue, wheather you click it at the finish line or just let off the gas.
Chris Hill
Old 11-04-2008, 01:02 PM   #15
Dave Goob Cook
Dave Goob Cook's Avatar
What about the lubrication circuits in an automatic trans, rolling 100+ mph with no lube supplied by the pump when you click the engine off?
I put my TH-400 in 2nd range at the stripe (no braking) and let the engine idle. Someone scared me out of taking it to neutral as I always had done previously.
I don't like the engine braking, because free load rpms are always bad, in my opinion.
"Despite the high cost of living, it remains popular."
Dave Cook
NHRA N375
Dave Goob Cook is offline   Reply With Quote
Old 11-04-2008, 01:13 PM   #16
Rusty Davenport
Liked 101 Times in 27 Posts
dave----is the no engine braking in second gear a special built in feature or does that exist in every 400 ???
read the engine braking section on the Turbo Action website and let me know what you think.......it gives a list of transmissions and whether or not they have engine braking.....is that for all transmissions or just turbo action ????
Rusty Davenport is offline   Reply With Quote
Old 11-04-2008, 01:57 PM   #17
THE LEGEND
Scene lots of nice cars torn up playing with the shifter at the traps!!!!!!!!!!!!!!!!!!!!!!!
Chip
THE LEGEND is offline   Reply With Quote
Old 11-04-2008, 02:10 PM   #18
SSDiv6
Chip
...and the reason why I recommend the Precision Performance Products Shifter...a very nice feature to have the ability to shiftl to Neutral after high gear. I wished they had the same feature for other transmission makes.
Old 11-04-2008, 02:43 PM   #19
trmnatr
So i guess the main question would be
With a TH400 that uses a Transbrake and no front band, would that harm the engine lifting in high gear past the lights and getting on the brakes to slow it down with the ignition and fuel still on??
Old 11-04-2008, 03:04 PM   #20
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Wink Re: Engine "Braking".......Does it hurt the motor ???
My car is an auto...rev. valve body no brake. Thing is my valve body had no drag in 1st or 2nd gear so i can just shift it up to neutral.
