Old 11-04-2008, 05:13 PM   #1
wesley montgomery
Default mod motor mustang stocker??
Does any body run a 99-04 mustang in stock or super stock with the 4.6 mod motor?? I am interested in seeing if one of these cars would be a viable combination in stock or super stock
wesley montgomery is offline   Reply With Quote
Old 11-04-2008, 05:25 PM   #2
Bill Harris
Liked 26 Times in 13 Posts
Default Re: mod motor mustang stocker??
Bret Velde runs an 03 (I think) in A/S. It's the 4.6L supercharged rated at 390 HP.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 11-04-2008, 05:35 PM   #3
wesley montgomery
thank you, do you know if anyone runs a n/a 2-v engine??
Old 11-04-2008, 06:07 PM   #4
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Rob Goins runs a 98 2 valve engine in stock
Old 11-04-2008, 08:18 PM   #5
Fred Popov
I have not seen any 99 to 04 2V Mustang in Stock Eliminator. I think that a lot of racers are afraid to try to build a race car out of the Modular motor. The 2v modular heads don't flow that well, even the PI heads (99-04) NHRA also doesn't have the specs correct for that engine either. The year 99 valve lift is listed correctly at 505/534 but they messed up the 00 to 04. (280/295) They should be the same. If I were to build one I would build a 01 or later because they have a little more compression and the same factory horsepower rating.
Fred Popov is offline   Reply With Quote
Old 11-04-2008, 08:20 PM   #6
wesley montgomery
thanks for all the info, maybe i should rethink using that car as a base
Old 11-04-2008, 08:59 PM   #7
Fred Popov
I like the 4 Valve DOHC Modular engines on the 96 to 98 Cobras. Stock the DOHC heads flow very well, even better then the LT1s and LS1s. The aluminum block is very strong with 6 bolt mains. I think that it would make a great high-winding engine. The only problem would be at tear-down. It would take more time to take appart.
Old 11-04-2008, 09:51 PM   #8
Just Observing
Only thing about the cobra 4valve is it is a stick only combo correct?
Just Observing is offline   Reply With Quote
Old 11-04-2008, 10:06 PM   #9
Fred Popov
Yes, stick only.
Old 11-04-2008, 11:18 PM   #10
Stang_Bang
Liked 2 Times in 1 Post
What about a 03-04 Mach 1??? 305 HP 4 valve and I think they came auto.....
Arjay
Stang_Bang is offline   Reply With Quote
