Old 11-11-2008, 11:03 PM   #1
Jim Whitehead
Liked 150 Times in 41 Posts
Default Aftermarket Disc Brakes
Any opinions, What brands? Any fit problems? good points? bad points? ect......... Any one care to say
Best Brakes for the money.
Thanks: Jim
Jim Whitehead is offline   Reply With Quote
Old 11-12-2008, 12:03 AM   #2
Bill Grubbs
Liked 564 Times in 66 Posts
Default Re: Aftermarket Disc Brakes
Best Brakes...LAMB.
Bill Grubbs is offline   Reply With Quote
Old 11-12-2008, 12:16 AM   #3
Jim Whitehead
Thanks Bill. Do you run Lamb Brakes on Brenda's car. If so How was the fit. Also what front wheel back spacing do you use. Thanks for any info....... JIM
Old 11-12-2008, 12:23 AM   #4
Mike Voth
Mike Voth's Avatar
Liked 57 Times in 14 Posts
We use Wilwood's lightweight, non-vented disc brake set-up. A little tricky initially to get the right caliper spacing on the rotors, and had to drill the rotor hats to fit our rear wheel stud bolts, but work light a dream. 3120lb car, 135mph+ and no warpage. Takes very little pedal effort to stop. Probably an easier application out there, but we're happy with the performance.
Mike Voth
5189 GTN - 5188 GTO
Voth Racing
Mike Voth is offline   Reply With Quote
Old 11-12-2008, 12:30 AM   #5
Chris DeGidio
Chris DeGidio's Avatar
Liked 2 Times in 2 Posts
I'm real happy with the Wilwoods I put on my car.
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
Old 11-12-2008, 09:24 AM   #6
Jim Whitehead
Thanks Chris, Thanks Mike, Hey Mike are you using the Wilwoods front and rear?
Old 11-12-2008, 10:59 AM   #7
Bill Pomponi
Best is Lamb. I put a set on the camaro last winter. Everything fit perfectly. You need to send them the spindles for check-out and assembly then a bolt in for you. Get the master cyl also, from him. trick set up. Very nice people to deal with. Using Mickey Thompson 75355071 Wheel Ultra ET Drag 15" x 3.5" w/BS 1.75". Plenty of clearance.
Bill Pomponi is offline   Reply With Quote
Old 11-12-2008, 11:02 AM   #8
Bill Pomponi
You have a PM.
Old 11-12-2008, 11:45 AM   #9
Bill Harris
Liked 26 Times in 13 Posts
I agree, Lamb are top of the line. Next time I build a Pro-stock car I will use them for sure. $3000 brakes on a stock/SS car seems a bit steep when you can put Wilwoods front and rear on most cars for about $1100. I have had the Wilwoods on my 3600 lb stocker for years and they work great at the starting line and at the top end, easy install, easy to get parts. Sure was an improvement over the OEM front disks and rear drums!!
Seems like a lot of cars have Aerospace brakes, but I have heard guys gripe about poor fit on some applications.
Guess a lot depends on your budget.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 11-12-2008, 12:28 PM   #10
Ed Wright
Ed Wright's Avatar
I'm a poor boy trying to do it on the cheap. I have Areospace brakes on my '96 firebird and the fit fine. Light, wheels roll easy and it stops just fine. They clear my Weld Pro Star fronts and Bagart rears with no problems. I have F.J. Smith's master cylinder setup. Been on there since 2003.
Ed Wright 4156 SS/JA
