359ci Naturally Aspirated Race Engine
Engine is being sold turn key with only 7 passes since being freshened with new rods, pistons, and rings. This engine is fresh off the dyno and made just over 800 hp! Listed are a few specs and will release all other specs for serious buyer. Small Block Ford: *359 ci 8.7 deck SVO Block *Bronze Lifter bores *Jesel keyway lifters *Roller cam bearings *Huge NA solid roller Cam (specs to buyer) *Edelbrock Glidden Victor Heads with all Titanium Valves (specs to buyer) *Fully Ported by hand Super Victor Intake manifold *Jesel Belt Drive *GRP Pro Stock Rods * LA Billet Crank *Patterson Pistons *Manton Pushrods *Jesel ultra Trick Rockers/stands (mowhawk) *Sheetmetal Valve covers * Your choice of a Pro Systems or Quick Fuel custom spec 4150 carb!!!!!! *CSR polished water pump *front and mid plates! *custom stock car single stage oil pump (belt drive) *Moroso vacuum pump (belt drive) *Moroso ultra 40 race wires *MSD crank trigger Engine is being sold turn key with all lines and fittings! Drop in and race!!!! Will start and run for serious buyer if needed. I also have for sale several converters and a full out Kilgore TH400 “ superlite” trans for sale. Will make a package deal if desired “The whole package” engine,tranny and converters. This set up has been 8.80’s at 2900lbs…. Add $3500 for Th400 and converter! $14k w/carb $13k w/o carb Any questions please contact Joe 281 802 4283 http://www.mustangmods.com/ims/u/1582/10024/262642.jpg |
