Old 11-24-2008, 10:37 AM   #1
KowalskyRacing
Default SS/HA 71' Duster am I figuring right ?
Can someone tell me if I'm figuring this right. I went on the NHRA site and saw the 71' Plymouth Duster with the hi comp 340 is factored at 314 hp and falls into the 10.04 lb weight break ( SS/I or IA ). Since you can move up or down one class, couldnt this be a SS/HA combination, and race weight with driver be 3153 lbs ( 314 hp X 9.50 lbs = 2983 + 170 lbs = 3153 )? I wanna know if I'm doing this right and also, has anyone ever ran a Duster in SS/HA ? Thanks for any help
KowalskyRacing is offline   Reply With Quote
Old 11-24-2008, 11:30 AM   #2
KowalskyRacing
Default Re: SS/HA 71' Duster am I figuring right ?
OK...I was looking at the Stock eliminator weight . My mistake. It keeps looking like a 360 is the way to go as far as the engine combination. I was hoping maybe a hi comp 340, but it just doesnt seem like the way to go.
Old 11-24-2008, 12:57 PM   #3
RJ
The intake port volume for the 2.020" valved 68-71 340 needs to be corrected. The same ~port volume is listed in the NHRA port volume specs for the 2.020" valved 68-71 340 as the 1.880" valved 72-73 340's and 74-up 360's?, it's not right and never has been. The port throat is bigger on the 68-71 high compression 340's, yet they need to adhere to the smaller 72-73 340 and 74-up 360 port volume? It's worth trying if NHRA corrects the 68-71 340 intake port volume. Probably why there are several competitive high compression 340's in stock where no volumes are checked, but super stock is lacking.
RJ is offline   Reply With Quote
