Old 11-27-2008, 01:11 AM   #1
dahkahuna
Liked 5 Times in 3 Posts
Default year end parts sell !
Ford 9" complete rear end re-enforced 44 " flange to flange housing with MW aluminum center pro 4:88 gears strange axles 5/8 studs..$4000.---Powerglide 1:76 billet hub Hipster brake,TCI shield and shifter and munsinger 8" steel stator super gas/comp convertor $2000./convertor only sep/$500.---Diest comp/super-comp parachute $275.---56" long chromoly solid wheelie bars $200.---Jaz 3 gallon vertical pro fuel cell $200.---Stock Elim. 8" 5300 stall convertor continental/munsinger refresh $600---1965-67 Chevy II 283 thick wall short block standard bore original crank rods pistons block #3862194 $550.--- complete Accel Lazer II ignition distributor etc,$400 ---GM 8.2 eaton 10 bolt posi-traction $250---1979 Pontiac 400 4 bbl engine and 350 turbo was running when removed $300---1984 Maseratti Quattro twin turbo 180 h.p. V-6 and auto trans-complete $800call Doug 909-632-8325
dahkahuna is offline   Reply With Quote
Search this Thread:
Advanced Search
