Old 11-27-2008, 09:57 AM   #11
Woodro Josey
Liked 3 Times in 1 Post
Default Re: Off season maintenance
Be sure and check the pedal components under the dash, on some cars it is hard to get to, but trust me, it will be worth the trouble to make sure everything is in safe working condition!
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
Old 11-27-2008, 10:28 AM   #12
LNorton
LNorton's Avatar
Liked 4 Times in 2 Posts
Woodro makes a good point. Right about the time that he had his wreck at Gainesville, I was about to make some updates on the pedals and brakes in our stocker.
At that point I went out and made sure I put in a stop so that the rod could not fall out of the master cylinder. I welded a nut where the brake light switch would be, and used a 1/2in bolt and another nut to lock the bolt in place. It is a little overkill, but now there is no way that the brake rod can fall out of the master cylinder on my car, unless the master cylinder physically breaks off of the firewall.
Lee Norton - N229 STK
IHRA H/FIA - NHRA O/SA
RacerTees.com
LNorton is offline   Reply With Quote
Old 11-27-2008, 10:59 AM   #13
Woodro Josey
Believe me Lee, i don't think you can be overkill in this area. However i had the stop and a bracket to keep the rod in but my rod came off the pedal end, it was held in place with a 7/16 bolt and a nylon lock nut which was installed in 98, so apparently over the years of use, the nut backed off, at a very dangerous time! Believe me, my next one will not come off like that one did!
Old 11-27-2008, 11:27 AM   #14
LNorton
LNorton's Avatar
I went out and made sure I had Grade 8 hardward holding the rod to the pedal. Also has a nylon lock nut on it with a lock washer. Every time I am down in the pedal area working, whether it be wiring or whatever, I be sire to check that bolt.
RacerTees.com
Old 11-27-2008, 01:23 PM   #15
Jim Bailey
Liked 584 Times in 94 Posts
Lightbulb Re: Off season maintenance
FRONT BRAKE ROTORS ! ! ! They crack. Throw a piece out, hit the brakes, (which we never do), you're going on your head.
Jim Bailey is offline   Reply With Quote
Old 11-27-2008, 02:31 PM   #16
Nitro Joe Jackson
Nitro Joe Jackson's Avatar
Liked 67 Times in 19 Posts
Thumbs up Re: Off season maintenance
Brake cailpers, check the bolts, i know it was a dragster, but thats what broke at the Dutch on Derrick Clark to make that dragster into a hall tree.
Everybody have a great time off, I know I NEED it!!!!!!!
Nitro Joe Jackson STK 3431
nitrojoe@neo.rr.com
Old 11-28-2008, 05:48 AM   #17
Bud Lefevre
Bud Lefevre's Avatar
I put my car on jack stands to keep dead weight off the tires all winter. Don't know if it helps, but can't hurt any.
Bud Lefevre 3075 STK
IHRA World Record Holder
Bud Lefevre is offline   Reply With Quote
