Old 05-10-2007, 09:00 PM   #1
Bad503
Default Epoxy instead of Cenent?
Is any one using or experimenting with any kind of epoxy instead of using hard bloc or cement
Bad503 is offline   Reply With Quote
Old 05-11-2007, 09:41 PM   #2
Bad503
Default
I have an old prostock bowtie block this block has some sort of what it appears to be Epoxy filling the bottom inch of the water jackets. ANY CLUES ???
Old 05-12-2007, 02:58 PM   #3
BillK
Liked 30 Times in 17 Posts
Default
Bad,
I wonder if your block was leaking around the bottom due to excessive relieving for stroke and the put in a little epoxy to seal it up ? I did it once to fix a small blow through from a broken rod.
As far as using it instead of Hard Block, I had a customer fill a block with some type of epoxy many years ago. The only thing I remember about it was that he ran the block ( 302 Ford ) for several years afterwards, and every winter when he was freshening it up, the bores had moved around a BUNCH ! I have never seen a block filled with Hard Block do that.
Bill Koustenis
Advanced Automotive Machine
Waldorf MD
Bill Koustenis
BillK is offline   Reply With Quote
Old 05-12-2007, 10:03 PM   #4
SSDA Hemi
SSDA Hemi's Avatar
Liked 451 Times in 77 Posts
Default
Probably Devcon epoxy. I've seen some older Pro stock pieces done with this. I agree with the epoxy moving around, heat definitely affects it.
SSDA Hemi is offline   Reply With Quote
Old 05-13-2007, 01:46 PM   #5
Bad503
Default
I have seen blocks filled with cement move around also, RU saying that Hard Block does not move around like Cement or Epoxy.
Old 05-13-2007, 04:39 PM   #6
BillK
Default
Bad,
I have not seen a block filled with Hard Block move around much. The one that was filled with epoxy was a mess, if I remember correctly it kept getting tighter each year ???
Bill Koustenis
Waldorf MD
Bill Koustenis
Old 03-04-2009, 07:57 AM   #7
henrys57wagon
henrys57wagon's Avatar
Default Re: Epoxy instead of Cenent?
Back in the 70's I use Devcon epoxy and as a machinist I saved a pile of castiron shavngs etc and mixed them in with the epoxy to fill a 350 block for stock. I put a hose through the drain hole facing up towards the deck to keep the drain open. A few years later a buddy used the block for a bracket motor, Henry. (old 1608)
old 1608 stock racer
henrys57wagon is offline   Reply With Quote
