Old 12-16-2008, 12:10 PM   #11
zracer305
Default Re: 1982-92 camaro
Originally Posted by Dragsinger View Post
I am unsettled about a torque arm front pivot design. Even after talking with S & W plus other racers, I still am not satisfied that a "poly" bushing at the front pivot is best.
I to have thought about replacing the poly bushing with a solid spacer. I have asked around and no body makes one. Wouldn't be hard to design one though.
Since I'm not worried about the 2x2 flexing here is how I braced the crossmenber to the subframconnectors.
Name:	Torque Arm Setup.JPG
zracer305 is offline   Reply With Quote
Old 12-16-2008, 12:36 PM   #12
Dragsinger
Liked 99 Times in 60 Posts
ZRacer,
your design looks good, I like the crossmember being triangulated to the frame connectors. Also, I like your idea about removing the poly bushing and building a solid bushing to replace it. I had not thought of that. This is a good example of our information age, I really like being able to share ideas & thoughts. A fellow can usually learn something! [smile]
Larry Woodfin 471W
Old 12-16-2008, 12:40 PM   #13
Dragsinger
by tha way, what is the length of the S & W torque arm? [center of axle to center of front bushing?]
Larry Woodfin 471W
Old 12-16-2008, 12:44 PM   #14
zracer305
Yes, there is a lot to learn on this site as well as others like it. The torque arm setup was new to me and I had to do a lot of research before I realized just how it works. I actually got to talk to the engineer who designed it for GM. To really make this setup hook and have you car 60' well there is a lot more than just bolting this thing on.
Old 12-16-2008, 12:55 PM   #15
zracer305
From what I understand it is 12" shorter that the stock one which I beleive is 56". That is from the top attachment point in the rear to the center point in the front. The shorter they are the harder hit on the tires.
Old 12-16-2008, 02:06 PM   #16
Bill Kennedy
Bill Kennedy's Avatar
Liked 37 Times in 11 Posts
We used the S&W stuff in our Firebird stocker. Never had any problems and picked the 60' time up quite a bit. You cannot go wrong with that set up!!!
Bill Kennedy is offline   Reply With Quote
Old 12-16-2008, 05:25 PM   #17
Rob Petrie E395
Liked 216 Times in 77 Posts
I wonder if the racers listed in their ad auctually use them un modified or they modify them. I am hoping Mr Josey,or one of the others in their add will see this and chime in as to how best to use them. (modified or unmodified) I am sure there is something better than what I am currently using (SLP subframe connectors and a adjustable torque arm that has the plate bolted up in the tunnel. very heavy but all that was available back in 95-96 when I started bracket racing current car) Its time update I just want to make sure what I buy is what is the best bang for the buck so to speak.
Once again thanks again for all your opininons/help
Rob
Old 12-16-2008, 08:21 PM   #18
monahan
Liked 5 Times in 2 Posts
just my 2 cents i have 90 pontiac formula j/sa 2x3 tubing for sub frame connectors eibach srings r/r air bag lakewood control arms stock sway bar stock torque arm with homemade frontmount/ driveshaft loop 60fts low 1.40s in j/sa thanks for listening gene monahan 1021 stk
monahan is offline   Reply With Quote
Old 12-16-2008, 09:46 PM   #19
zracer305
I have seen your car and have always admired how well it hooks up on the starting line. If you don't mind me asking...What are your 60' times and what anti-roll bar do you use?
Old 12-17-2008, 11:21 AM   #20
keith ohanesian
He doesn't use an anti-roll bar Gene has the stock sway bar. It is the old school set up air bags and sway bar. And hell it works!! Might be better with the s and w stuff. Who knows does some one what to donate so he can back to back the set ups????
No prep is king
keith ohanesian is offline   Reply With Quote
