Old 12-16-2008, 12:28 PM   #51
Lynn A McCarty
Lynn A McCarty's Avatar
Default Bogus
Why dont we just get rid of the runner volume rule? It is a good idea gone Bogus bad!
Lynn A McCarty 3470 SS
Lynn A McCarty is offline   Reply With Quote
Old 12-16-2008, 01:29 PM   #52
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
Default Re: Cylinder Head Runner Volumes
Originally Posted by Alan Roehrich View Post
Look in the Lucas oil section on Monday. Bruce Bachelder said that in 2009 they would monitor port volumes in cylinder heads in Stock Eliminator, if your port volume is found to be larger than what is listed for Super Stock, you will be disqualified from that event. In 2010, there will be a published specification for Stock like there is for Super Stock.
Could someone please pull this forward and post here. I cant seem to find where this is on the site......
Thanks......Wade O
Old 12-16-2008, 01:45 PM   #53
Tommy Gaynor
Tommy Gaynor's Avatar
Liked 5 Times in 3 Posts
I just received an Email from Bruce 5 minutes ago and there is going to be a CC max for stock!!! He said the new policy will be on the website today! I guess we all need to start hunting for the "good" castings. Merry Christmas engine builders.
"Go With Confidence"
Tommy Gaynor is offline   Reply With Quote
Old 12-16-2008, 01:47 PM   #54
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
This might be it.Maybe not.
http://www.nhra.com/tech_specs/runners/index.html
Old 12-16-2008, 02:15 PM   #55
zracer305
Originally Posted by 442OLDS View Post
No, this is for SS and has been posted since the 12/03.
zracer305 is offline   Reply With Quote
Old 12-16-2008, 02:39 PM   #56
442OLDS
442OLDS's Avatar
I'm confused,but I thought that is what all of this is about.Currently,there are cylinder heads being used in Stock Eliminator that aren't even legal in Super Stock Eliminator.That is how I understand this.
Old 12-16-2008, 02:54 PM   #57
zracer305
You are 100% correct. There are a lot of heads out there with volumes bigger that what's allowed in SS where its legal to do port and polish, raise and lower ports use epoxy and so on. Yet, NHRA has allowed player in stock to get away with larger volumes. How can this be done if acid porting is not allowed. If they put the correct limits to runner volumes you're going to see a bunch of people slow down.
Old 12-16-2008, 03:19 PM   #58
Bruce Noland
Liked 444 Times in 145 Posts
We go through this stuff all the time. Anyone remember the piston deal? Lots of folks were talking about all the racers who were going to slow down. You know what, the fast guys are still fast. This head runner volume thing is way over blown too. Sure some racers are out there with oversized runners but I'll bet there are not as many as some of you think!
Bruce Noland 1788 STK
Old 12-16-2008, 03:28 PM   #59
Jeremy
There is a problem some of the small block Mopar SS volumes are incorrect with the valves we can now run. I've checked many untouched small block mopar heads this year and very few have four runners that will meet the ss volumes (only one out of twenty heads for the 915's I checked had four runners that were less than the ss volume of 158.). The 587 head is the only exception,it has the same port but there is 4 cc's difference in the super stock spec.
I was told at the pri show the stock volumes were decided on Thursday evening and would be on the NHRA site Friday or Monday.
Thanks
Jeremy is offline   Reply With Quote
Old 12-16-2008, 07:35 PM   #60
Bub Whitaker
Thanks...
Bub Whitaker is offline   Reply With Quote
