Old 12-25-2008, 11:23 AM   #21
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Talking Re: Older Superstock GT cars with scoops
It seems the combo's are unlimited. How about a 1963 Z-11 (Old Reliable) alum. front end Chebbie (real or cloned) with a 396/375 or a 454. Maybe a 283/220 for GT S/S since NHRA lists the Z-11 in the guide for S/S and a heavy duty rear would be legal. Lots of luck finding the Alum. parts. Just to show how the combos could become wild. No more nuts than a 68 Hemi Dart or 'Cuda with a 273 or a T-Bolt with a 289. How about a 60 Chevy wagon like Jack's stocker with an L-88 or ZL-1 engine combo? Then he could use a 3 speed auto without any grief from the tech dept. Then theres always a 64-65 GTO with the 421 SD engine or a 455 SD. A '66 Mustang with a Boss 429 Hemi (if it would fit). And some of you guys think IHRA's GT stock class is screwed up. Gezzzzzzzzzzz. LOL It sounds like "HEAVY" eliminator with engine spec. rules to me.
Old 12-25-2008, 11:31 AM   #22
SStockDart
SStockDart's Avatar
Liked 574 Times in 212 Posts
Default Re: Older Superstock GT cars with scoops
I haven't talked with Jim Hale in a while, however, he told me some time back that he was building a 383 Super Stock engine for his lightweight Barracuda. I am reasonably certain that the hood scoop on the Barracuda is functional. If it is required that "fresh air" be required on the replacement engine, one could simply claim a 69 - 70 Roadrunner. Both had "Air Grabbers". I do not believe that NHRA would make you close a hood scoop... As an example, I have a 69 Roadrunner with an Air Grabber. The HP rating is the same for a plain hood or the fresh air hood. However, their can be a different HP rating for the engine whether it is in Super Stock or GT. So, my suspicion is that the hood scoop will be allowed to be open, then HP adjustments will apply for GT classes.
Old 12-25-2008, 12:26 PM   #23
Jeff Teuton
Liked 325 Times in 50 Posts
We will debut out GT/CthruFA (383 or 440 combo) which I have gotten OKed. It is a 68 Hemi cuda clone with the scoop and the glass. It is a recognized model in the books. Same as Jim Hale. Should not be an issue as we run a faster index or more hp that the same car in SS ie a 70 cuda with the 383 is .05 slower indes than my car with the 383. We have converted this Top Stock car to SS, and are doing the same with our 70 Duster.
Jeff Teuton 4022 STK
Old 12-25-2008, 01:54 PM   #24
Jeff Lee
Jeff Lee's Avatar
Originally Posted by Shawn Blair View Post
One good reason for the scoop would be carb clearance, this would be a good thing if running the 1962 343horse 383 combo with a tunnel ram. I'm still waiting to see that one! It would have to be fast with those two carbs.
Yes, open or not the key is carb and manifold clearance. A budget racer could take a 380 2x4 carb and use your basic Weind cast aluminum tunnel ram under one of these scoops. A lot less money than a sheet-metal tunnel ram; and possibly more effective. I would think the tall scoop would open up some new technology for the 6-pack 340/440 intake manifolds as well.
Looks like Teuton and Hale have the open scoop issue worked out with NHRA. Jeff, are you considering the 383/343? I guess a 440/375/350 engine would also be a killer. Guess you could even run a Weind/Edelbrock single 4bbl tunnel ram in that car, on any mopar engine.
Jeff Lee 7494 D/S '70 AMX
Old 12-25-2008, 03:12 PM   #25
X-TECH MAN
Banned
Smile Re: Older Superstock GT cars with scoops
Same deal for the 55-57 Chevy's. Theres room for a tunnel ram on any of the 350/327 engines in these cars and clear the hood as on the 265's they run now. How about a killer 318 or 360 for your AMX? Like I said the combinations are almost unlimited as long as the 8 lb. minimum for GT is met. I guess a 4000 + lb GT/A car with a race Hemi would be unreasonable.....lol.
Old 12-25-2008, 08:58 PM   #26
Jeff Teuton
We have a 383 and a 440, and we might try a 440-6 in the future. We expect to test in 2 to 3 weeks
Old 12-26-2008, 12:44 AM   #27
Bryan Broaddus
Liked 18 Times in 4 Posts
I asked Bruce Bacheldor at the Finals in Pomona about running the 69 Corvette in GT with the L-88 hood. He said no on the hood! He didn't offer any reason and I didn't push it.
Bryan Broaddus 7568 STK ,SS
Bryan Broaddus is offline   Reply With Quote
Old 12-26-2008, 01:30 AM   #28
bill dedman
Liked 6 Times in 4 Posts
I was GOING to suggest that the rationale behind open or closed-off scoops would logically lay with the engine's original horsepower factor; if the engine was out of a car that had fresh air, then the factord HP rating would reflect that, and in a different chassis, then it would be legal with an open scoop (fresh air.) That made all kinds of sense to me. Anything else, and you're not being true to the original operational parameters that gave the engine that particular factor in the first place.
THEN, before I made a complete fool of myself by posting something that had a hint of logic to it, I decided to go and see how much factored HP difference there was in the so-called "Ram-Air" (fresh air) packages that used open scoops, and the ones that didn't (otherwise identical engines, like the early Cobra Jat Mustangs, some of which had "Ram Air".)
Guess what??? NO DIFFERENCE! At some point, NHRA has decided that a fresh air package is worth NOTHING in terms of factored horsepower... but, they stilll list the different (fresh air or no) combinations.... they just give them identical horsepower.
Admittedly, I only looked at a few examples, but it was obvious to me from what I saw, that NHRA had gone through the list and either cut the fresh air motors back to the closed-in, no scoop models' factored HP ratings, OR upped the rating on the no-scoop models to match the fresh air engines' factors.
I must not have been in class that day.... That phenomenon has come about totally without my having noticed it.
Beings that there's no difference in the ratings, why would they CARE which engines have operational fresh-air systems??? I can't imagine that they would.
So, this is one in which there IS no argument that I can see, that scoops that were on a car would have to be closed off, because as NHRA has shown us in their sacred Classification Guide, they aren't worth even ONE HORSEPOWER.... Check it out...
Admittedly, I didn't check them all, but I did look at several combinations that had both underhood air vs. fresh air, and all the ones I looked at had identical factors.
It is a mess...
Bill
Bill
bill dedman is offline   Reply With Quote
Old 12-26-2008, 08:46 AM   #29
Myron Piatek
Liked 138 Times in 51 Posts
Question Re: Older Superstock GT cars with scoops
I believe NHRA use to have an automatic 5 HP factor for fresh air combos - '70's?
LOCOMOTION Racing
Old 12-26-2008, 12:02 PM   #30
Jeff Lee
Jeff Lee's Avatar
It is a mess...
Bill
Sorry Bill, that occured maybe 20 years ago? I'm not sure when but it was a LONG LONG time ago. It's a technicality as to when and why but I'm under the impression it was a result of 428 CJ racers changing hoods from flat (Q code) to shaker (R code) and NHRA seeing it didn't seem to affect performance one way or the other. I can only offer my own experiments on my '70 AMX. I was curious in D/S what the affects were. Sealing off the scoops (which probably aren't much more; if any, effective of something like a mopar / ford shaker), and even running with and without a K&N filter I found no ET one way or another and MAYBE as much as (point) .2 MPH. And that's on a 124-125 MPH stocker.
I'm sure a 145-150 MPH SS car like a SS Dart/Barracuda or SS/AMX would see different results but NHRA has, as Bill pointed out, set the bar across the board that it doesn't seem to matter.
I still contend the scoop is a body part not an engine part and if NHRA allows cars like Hale or Teuton (non-hemi in '68 hemi A-body SS/GT car), then it should be across the board. That would include the SS/AMX scoop and the L-88 Corvette scoop.
