Old 12-30-2008, 11:06 PM   #1
Dion Hildebrandt
Dion Hildebrandt's Avatar
Question front tire recomendations
I am getting ready to purchase new front rubber and i figured i would see what most of you guys out there were using as far as size goes. Also what the reason is for the size choice. any thoughts would be helpful and thanks for any replies.
Dion Hildebrandt 6009 STK H/SA
Dion Hildebrandt is offline   Reply With Quote
Old 12-31-2008, 12:27 AM   #2
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
Default Re: front tire recomendations
Moroso Drag Specials if you can fit them. Not the lightest tire but look good.
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 12-31-2008, 02:44 AM   #3
LNorton
LNorton's Avatar
Liked 4 Times in 2 Posts
How about a smokeless unit?
Lee Norton - N229 STK
IHRA H/FIA - NHRA O/SA
RacerTees.com
LNorton is offline   Reply With Quote
Old 12-31-2008, 09:36 AM   #4
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: front tire recomendations
I choose front tire size based on the reaction times I get when staged "comfortably". You can fine-tune RT's with air pressure, staging rpm & bumping, but the diameter gets me in the ballpark, as long as you have enough fender and ride height clearance. Taller for more rollout, slightly faster ET's and slower reaction times and, of course, the opposite for shorter tires.
As for brand, I just match the 28" fronts to what I run on the back, Hoosiers.
LOCOMOTION Racing
Old 12-31-2008, 03:47 PM   #5
Dion Hildebrandt
thanks Myron i was leaning towards a 28 or 29 tall the car seems to redlight easy. i think the current tire is 26 tall.
Old 12-31-2008, 06:10 PM   #6
Bobby Zlatkin
Bobby Zlatkin's Avatar
Dion,
I have a pair of new Firestone 28" front drag tires that I would sell for $100 plus shipping. Never been used.
bobbyz@ioa.com (828) 891-2522
Bobby & Norene Zlatkin L/SA
Bobby Zlatkin is offline   Reply With Quote
Old 12-31-2008, 07:55 PM   #7
Darcy Clarke
Liked 529 Times in 36 Posts
Hi Dion,
I use Moroso on both of my Dusters with good luck. I use 28" on the stocker and 26" on the no box both seem to last well.
Darcy
Darcy Clarke is offline   Reply With Quote
Old 12-31-2008, 08:56 PM   #8
Greg Barsamian
Liked 427 Times in 97 Posts
Dion, I use 7.60 x 15 Moroso Drag Specials on the front of my 70 Chevelle.
It has trick springs with a full coil removed.
Good Luck
Greg
Old 12-31-2008, 09:27 PM   #9
55 Chevy
55 Chevy's Avatar
Liked 20 Times in 15 Posts
I use the 7.10 x 15" Moroso Drag Specials . They weigh about 12.5 lbs & clear my headers nicely. The 7.60's are a bit too tall & rub on the way down on one of the tubes. With the "Flys" they come in at 21.6 lbs.
55 Chevy is offline   Reply With Quote
Old 01-01-2009, 02:28 AM   #10
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Wink Re: front tire recomendations
I run the 27.5 M/T they work great. I had the Moroso DS 2 on my last car & they didn't last to long?
