Old 12-26-2008, 04:31 PM   #1
Rory McNeil
Question TOYO Stocker slicks?
I see that Toyo lists 3 sizes of "stickshift" application 9" slicks designed for Stock eliminator cars, has anybody ever tried them on a stick car? I`ve been running the M/T 3056ST "stick" tires on my 85 Mustang, but a slightly shorter tire would help gearing wise. Also, since Coker Tire has taken over the Phoenix brand, is anybody aware if the F14 "stick" compound is still available, and how it compares to the old Firestone tires?
NHRA 6390 STK
M/S 85 Mustang
Old 12-27-2008, 11:09 PM   #2
Cam
Cam's Avatar
Default Pm
Rory, you have a PM.
Cam
Cam is offline   Reply With Quote
Old 12-28-2008, 12:16 AM   #3
Jim Storms
Liked 4 Times in 2 Posts
Default Re: TOYO Stocker slicks?
Rory, Jim Devine runs them on his Duster, i just traded him a new set that i was going play with on the Challenger!, but the 4spd. was sacraficed to a auto so no need for them, he says small burn out. they work for him. im sure it depends on the H.P. of the car.
Jim Storms is offline   Reply With Quote
Old 12-28-2008, 02:32 AM   #4
Rory McNeil
JIm, did you sell your Jerico stuff yet? Also where did you buy the Toyo slicks from? Thanks.
NHRA 6390 STK
M/S 85 Mustang
Old 12-28-2008, 01:11 PM   #5
Jim Storms
Thumbs up Re: TOYO Stocker slicks?
Rory, Les Schwab tire stores down here in season they were $190.00 a pair, i believe Gary Mckoy want's the stuff, ill check with him!, why do you or some you know. it needs to go!
Old 01-02-2009, 02:42 PM   #6
Shawn S.Kvaas
Hey jim.What do you have for 4 speed stuff?Shawn
Shawn S.Kvaas is offline   Reply With Quote
Old 01-02-2009, 05:11 PM   #7
Jim Storms
Hey, i have everything i took out of the challenger, it's big block sheild, Mcleod soft lock, & the jerico trans.308 first gear. basicly from engine to drive shaft. plus shifter.
Old 01-02-2009, 05:50 PM   #8
Rod Greene
Liked 242 Times in 81 Posts
Jim,How much for the trans?
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 01-02-2009, 06:03 PM   #9
Jim Storms
Question Re: TOYO Stocker slicks?
Rod. don't have a clue! give a call 425 941-8765
