#11 |
Liked 279 Times in 68 Posts
Jeff I also talked to Bruce more than once last year about this. I think this was a mean spirited and punitive rule change that didn't come from Bruce but farther up the food change. I really think they don't care.
Greg |
#12 |
Liked 1,925 Times in 579 Posts
Hey Daran. Jay Slane had similar results with a set of 441 heads that he is working on. All of the small block heads that I have CC'd before porting have come up about 6 CC's smaller than the SS limit. I am not sure how that compares with big block or other brands. NHRA will probably just allow some mild porting and epoxy in the intake and welded exhaust like SS. They couldnt control the head rule in super stock so they changed the rules. They will probably do the same for stock. Then a good set of heads will cost 7500.00 but you wont have to worry about passing teardown. As long as the valve size is correct and the CC's are right you will pass.
Mike Pearson 2485 SS |
#13 |
Liked 3 Times in 1 Post
Daran, FYI, there are 2 different castings in the 441's one type is bigger on intake runners than the other!
Woodro Josey 2002 STK |
#14 |
Liked 968 Times in 194 Posts
Why dont they just add 2 or 3 percent to all the SS volumes,and use that for both the STK and SS numbers? They should only have one list.Will be alot less confusing when you race a stocker in SS.
#15 |
Liked 5 Times in 3 Posts
I have to agree with Lyn...their are alot of guys that run both S & SS with the same car. I also have a question on the head volumes...what about the cars that have NO #'s like our 6cyl nova? I don't see any #'s for a 230!
#16 |
Liked 4 Times in 1 Post
DARAN:
161 CC is the spec for the intake side. My intakes were safely under the spec as well. It's the exhaust side that is way too close for comfort. Same result now on 3 sets.
Tony Curcio 1860 STK |
#17 |
Liked 3 Times in 2 Posts
Who's to say the numbers used for Super Stock are really "right" anyway.
I'm sure no scientific methods were ever used to arrive at the magic numbers we have to use. As Woodro says , there are different castings made at different foundries that definately have different volumes when made. I for one like Lyn's idea to add 2 or 3 percent and get on with it. FJ |
#18 |
Liked 880 Times in 311 Posts
Just a little insight to the production of heads. My buddies at Brodix tell me that a fresh core box will produce heads that are on spec. I assume that means port location & cc's because they say at the end of a production run the core boxes are showing wear & the port volumn will be smaller than designed. I would think the same applies to any automaker produced heads. The Design/R&D guys at Brodix have used the term "Filed" core when talking about producing a bigger runner head. Hey, the pattern maker has a bad day on Monday & the molds are off spec. He sobers up by Wed and is feeling good so he makes some molds over spec. At that time of original design & production little did they know that the quality of their work & a few CC's would mean so much to racers.
Adger Smith (Former SS) |
#19 |
Liked 34 Times in 7 Posts
Consider this,
Maybe NHRA is trying to make the cylinder head issue so oblique that it will facilitate the introduction of "spec" heads from the aftermarket. If an aftermarket supplier can supply 80-90% of the class and provide accurate port dimensions, cc min and max, cross section, templates all of a sudden it makes sense.Will there ever be a 230 6 cyl head? Probably not, but the amount of those types of combinations are no where near the amount of sbc/bbc/ford/dodge V8s in stock(nitro joe would know). Is this "pure" as the old "stock" eliminator, probably not. If someone can buy some performer rpm (or whatever is approved) heads and build a stocker, it would appeal to a broader group (mostly those that do not see the merit of all of the hard work). I am not trying to p anyone off, ( I deeply respect what stocker engine builders can do) but when someone asks me if they can build a stocker and you explain what some of the stuff really costs they get intimidated. I am not trying to discount the efforts of those of you who are really good at what you do, but if NHRA will not consider the knowledge of Woodro, FJ, and any of the stocker "head guys" (even their own "pouring" records) what could possibly be next? They (NHRA) obviously have a different agenda then what meets the eye. |
#20 |
Liked 32 Times in 19 Posts
New 207 carbs, New Aluminum heads for big blocks, New cranks, new rods new pistons to spec sheet. New Blocks for strength. We are there now we just need to find a company who wants the work. World might be the one to do it. Why buy old rusty castings and spend the work to be off on CCs and worse create all this foolishness of tech currently sees. Make some good ones with todays technology and move forward. Cut the crap and cost at the same time.
I hate to say it but I think making one casting for small block low pro and one for high compression for ALL stock and SS would be the smart way to create the large number needed to justify making them. Simplify tech and stop the frustration in tear down. One casting of any family of motors the same thing. Just think it would also help stop the tech book finding an obscure combo wrongly factored and ignored by tech for 5 years too.. Thanks for listening... Dick |
