Liked 275 Times in 76 Posts
This was just posted on UMTR
Posted - 01/10/2009 : 3:59:08 PM -------------------------------------------------------------------------------- The following are the minutes from a SFI meeting, where the main discussion was the possible acceptance of a window in a 6.1 passanger car bellhousing Specification Review Meeting Minutes Bellhousing Committee – Specs 6.1, 6.2, 6.3 Friday, December 12, 2008 Performance Racing Industry Show Orange County Convention Center – Orlando, FL Attendees Kyle Jackson DHRA Gene Mohney NADM Brian Browell Browell Bellhousing * Ross McCombs Quicktime, Inc.* William A. Pasco III Lakewood* Jim Puskas Lakewood* Dave Flory ProBell Racing Products* Tim Hyatt Hyatt Racing Services* Mike Miller Trick Titanium* Arnie Kuhns SFI Jennifer Faye SFI *denotes committee member SFI President and CEO Arnie Kuhns called the meeting to order at 1:00pm. It was explained that existing specifications must be reviewed on a periodic basis to ensure their relevance to current field conditions. It was previously asked of the committee to submit in writing any suggested agenda items prior to the meeting. It was noted that attendance for this committee did constitute a quorum, therefore official business could be conducted. The comments of those in attendance would be heard and a report will be provided to the full committee. The committee began by discussing the one agenda item that had been previously submitted: allowing a lower adjustment slot in a 6.1 bellhousing that would enable access for adjustable clutches without end users making their own holes or improper modifications to the bellhousing. This would be for passenger car replacement bellhousings only. It was suggested to create a new separate spec for this application, such as 6.1W (for window). The following are all items that the committee would like incorporated into a draft: In such a new spec, the window should be reinforced. The new spec would omit the wording about the adjustment opening being located past the rotating clutch assembly. There would be a separate sticker on the window itself. The window should be as close to the transmission end of the bel lhousing as possible, such as a 6.2. It was asked what kind of clutches these bellhousings would be used with. It was stated it was mostly for Stock and Super Stock class cars and a dual disc would be the most discs they would use, with a relatively small diameter. The bellhousing with the greatest depth would be tested to cover all like models. The committee needs information for possible assembled clutch heights. Tim Hyatt volunteered to compile this information. The committee needs to determine dimensions for the smallest useable hole size based on this clutch data and a shallow bellhousing. The window will have to be located on the lower quadrant because it’s for a passenger car application. The spec should require a recertification life to prevent unauthorized modification (1 or 2 years). The window should be an oval-shaped hole. Tim Hyatt volunteered to send the clutch info he acquires to SFI for distribution to the full committee. SFI would then coordinate R&D testing with the manufacturers. The committee will then meet mid-year 2009 to review its findings. A possible location would be during the NHRA Norwalk race in June. The committee had no other items to discuss regarding Spec 6.1. Next the committee addressed Spec 6.2. It was pointed out that a 6.2 bellhousing is tested with a flywheel with ring gear, but in actual use, there is no ring gear installed. It was proposed to revise Spec 6.2 to use a test flywheel that has no ring gear. The committee voted and unanimously passed this proposal. The proposal will be sent to the SFI Board of Directors for final approval. There were no other items to discuss regarding Spec 6.2. The committee had no items to discuss regarding Spec 6.3. With there being no further business, the meeting adjourned at1:35pm. Respectfully submitted, Jennifer Faye Program Manager
Liked 1,436 Times in 299 Posts
That would be a great deal! I have talked to several on this issue, but never dreamed SFI would even hear it. I sure hope it happens. Changing counterweight without pulling the bellhousing would be a real treat!
My brother and I put a QuickTime bellhousing on our car this year and it is very nice. It is steel, but it is smaller, fits better and is 12lbs lighter than the Lakewoods that we had been running. I have some pics of it if any stick guys are interested. PM me or e mail. jimschaechter@earthlink.net
James Schaechter 3163 STK |
Liked 427 Times in 97 Posts
Why not a 5-year certification on a Scattershield with a window?
Jim, I am having trouble getting e-mail to you. Could you send some pictures of the bellhousing to me. Thanks Fastman68@aol.com
Liked 1,598 Times in 583 Posts
The problem at SFI is Arnie Kuhns...he needs to be replaced by some one with a lot of more knowledge and common sense.
#6 | |
I agree. Can anyone explain the logic behnd 1-2 year certs on S/SS scattershields? " The spec should require a recertification life to prevent unauthorized modification (1 or 2 years)." Cam |
Liked 20 Times in 15 Posts
good for only two years if this is approved?
So would that make my scattershield I just purchased(without an adjustment hole) good for only two years if this is approved?
What they are saying is 6.1W would require re-cert sooner than the 6.1. W for "window"" bellhousing.
See www.quicktimeinc.com for their bellhousings. What Jim said was correct, nice, light bellhousing. More floor space too.
Jeff Lee 7494 D/S '70 AMX |
#10 | |
Just like "PICKLED" heads and intakes I guess !!! |
