Closed Thread
Old 01-19-2009, 07:26 PM   #201
Bruce Noland
Liked 444 Times in 145 Posts
Default Re: Factory experimental
Ed,
Only you.
Bruce Noland 1788 STK
Bruce Noland is offline
Old 01-19-2009, 08:34 PM   #202
John Warehime
Liked 2 Times in 1 Post
Talking Re: Factory experimental
Every car ever built was a factory experiment.
John Warehime is offline
Old 01-19-2009, 09:18 PM   #203
GUMP
Liked 2,354 Times in 554 Posts
Originally Posted by Bruce Noland View Post
Tim,
The 425 Horsepower rating for the new Mustang is supposedly a best guess figure because they don't have any history on this car's performance. The 400 rating on the 396 is based on 40 years of evaluations. The 720+ Horsepower figure was given to me at SEMA. The most potent Stockers on the track make 80 to 100 horsepower less than the new Mustangs. nhra and Ford should have put these cars in Factory Experimental or a class like AAA, if they were at all interested in fairly classifing these cars. It may take them awhile to get these cars settled down; but they will. Indy should be the proof in the pudding.
Would you say that the factory horse power rating on your Camaro was a little soft?
GUMP is offline
Old 01-19-2009, 09:38 PM   #204
Jared Jordan
Liked 539 Times in 120 Posts
Send a message via AIM to Jared Jordan
One aspect that hasn't been discussed in this thread is the effect the supercharger will have on those cars at an altitude track. Those of you in the Eastern U.S. don't have nearly as many of those as we do out West. If you're getting blown off at sea level by one of these cars how much further behind are you going to be in thin-air against a forced-induction vehicle?
I'm not railing against the Cobra Jets. I think it's fantastic that the factories are injecting new technology into both Stock & Super Stock, but I worry that the playing field won't be entirely level. I never understood the uproar over injected cars vs. carbureted cars. As it turned out, there wasn't as great of a difference in performance as many feared would exist. Perhaps this is the case here, though I don't believe it to be so.
I don't currently have a "dog in the fight" so to speak, but 430 HP seems a little low. If these engines are indeed making 700+ HP (I have no doubt that they are capable of doing so...), then 3395 lbs in AA/SA and 3610 in A/SA seem a tad light. These cars will be capable of bettering the -1.40 number required by the AHFS out of the box, but I guarantee you won't see one go that fast for a couple of years. The system remains the problem, not the car(s). A truly "automatic" system without any degree of human input will never effectively maintain a level playing field. Systems can be manipulated. Common sense cannot.
Jared Jordan
9 B/SA
2024 Jeg's D7 All Star - Stock
Jared Jordan is offline
Old 01-19-2009, 10:10 PM   #205
bsa633
Banned
Exuse me for being a little "slow"..but is it the "Roush car" that will be at Pomona or the "Cobra Jet" like NHRA says on thier page..i am a little confused...maybe this is going to be the same as the old Shelbys..what combo of the week are you running?..small valve,big valve,Dove,Edelbrock and so on..
bsa633 is offline
Old 01-19-2009, 10:30 PM   #206
Jim Bailey
Liked 584 Times in 94 Posts
Jared, That's where the fun's gonna begin!!!! Superchargers!!! OMG!!! I can't wait to get my hands on one. Just a quick "romer' ( CNC ) trace of the rotors and away we go!!! Change the Helix a degree or two ( they'll never see it ) Seal the hook with nylatron ( it's probably an air lock design) and Teflon tubing in the valleys, just for starters. Then seal the end plates , also with nylatron. We'll cryo must of the internal parts then coat them with some type of teflon/moly coat. We'll get the intake charge down about 20 - 50 degrees. Even run it slower than designed, make it efficient out the ***!! It'll make enough boost to blow the crank out of it with VP -C25. Limit us on pullies? Who cares? This is gonna be fun! (And if you think they don't know what's going on with electronics?) Just wait.............
Jim Bailey is offline
Old 01-19-2009, 10:30 PM   #207
DK FRAZIER
Gump, You would think if factor on Bruces camaro was that soft there would alot more of this combo out there. I would guess more like hard work on his part !!!
Doug Frazier D/SA 2038
DK FRAZIER is offline
Old 01-19-2009, 10:44 PM   #208
Chad Rhodes
.....................and that would be the rest of the iceberg thats lurking under the surface.
Conspicuous by its absense in the blueprint specs is ANY specification on the Eaton Supercharger. No Part numbers, inlet size, dispalcement, outlets deminsions,rotor helix, case clearances or pulley sizes. No reference to factory boost levels.
Chad Rhodes 2113 I/SA
Chad Rhodes is offline
Old 01-19-2009, 10:54 PM   #209
GUMP
I'm not doubting that he has worked hard and I really doubt that it is under factored now. What I was getting at was that it was just a little bit under factored (in regards to Stock Eliminator) as delivered from GM. IMO the same applies to the Cobra Jet.
GUMP is offline
Old 01-19-2009, 11:01 PM   #210
Tom P
Liked 239 Times in 94 Posts
The Cobra Jet really is an 08 Shelby GT500 with less weight and a few racing modifications already done, some normally allowable in Stock and a few that aren't. A GT500 would be legal already, they've built thousands. Ford doesn't really need many of the mods to sell the car to racers who can change that stuff.
I think it'll be interesting to see what happens.
Tom P is offline
Closed Thread
