Liked 54 Times in 7 Posts
I am in the middle of installation of a S&W roll bar kit in my 77 Camaro. I want to keep the back seat so I ordered up the extra long bars that run though the package tray instead of the rear seat. They are long enough to run all the way back to the taillight panel.
My question is should I run the bars all the way back to the rear of the trunk which will tie the bars into the rear leaf spring perches, or would it be best to have another bend put in the tubes to drop them closer to the shock mounts? Thanks Chad |
Liked 1,827 Times in 414 Posts
I'd run them all the way to the back, and if you want to add a little stiffness, drop a kicker off of that bar on each side to about where the shock mounts are. There's probably about a 3-4 pound weight gain there, but on a stock floor pan car, the added stiffness is worth it.
Alan Roehrich 212A G/S |
Liked 14 Times in 11 Posts
Chad,
I am having the S&W roll bar kit installed in my 1974 Duster right now, no rear seat, but my two rear bars tie into the top of where the rear part of my frame connectors are welded which is a few inch's ahead of the front of my spring mounts.
Phil Saran Parker, Colorado |
Liked 54 Times in 27 Posts
By the time you weld in the required crossbar, the rear seat will be virtually inaccessible. Might as well save the weight, remove it and make up some "upholstery" and a piece of carpet.
Liked 33 Times in 17 Posts
Chad,
You have a PM. |
