Old 02-17-2009, 07:01 PM   #11
RJ
Default Re: Stocker pin dia.
I got a response back from NHRA today, has to be the .945" pin in this case, looks like I'll be boring the new rods and buying new pins.
RJ is offline   Reply With Quote
Old 02-17-2009, 07:20 PM   #12
bsa633
Banned
Originally Posted by RJ View Post
There are plenty of .945" rods available, but none of them made the list. So the legal rod with it's .927" pin and pin bore supersedes the stock diameter pin requirement?
Does the rod really have to be on the approved list in Stock?? as long it has the right pin bore and housing bore correct length(unsure about Ford FE ) made of steel and the total weight of the assembly is greater than published one should be fine..wouldn't you think??I would belive with the total assembly weights in stock the rod list is more for SS!
bsa633 is offline   Reply With Quote
Old 02-18-2009, 07:35 PM   #13
BRUCE PARSONS
Banned
RJ If you got a response from Pat Cvengros at NHRA in Ca, take it with a grain of salt. If you got it from Wesley than it will be as he says. I was told last year that all pistons must be the same as the example that was on there shelves in Ca. I wonder what the pin sizes are on the examples and why does the approved list show .927.
Bruce
BRUCE PARSONS is offline   Reply With Quote
Old 02-18-2009, 08:18 PM   #14
Woodro Josey
Liked 3 Times in 1 Post
RJ, back in 1998-99, NHRA approved the 927 pin because the aftermarket pistons were being made with 927 pins and also Manley Rods. I think Pat is missing something there.
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
