Old 02-20-2009, 03:21 PM   #51
Bruce Noland
Liked 444 Times in 145 Posts
Default Re: Next Debate.
The dyno numbers would be very helpful in determining a fair nhra factored Horsepower. Dynos have been around for a very long time and most good shops can pin point actual Horsepower and Torque numbers. This isn't rocket science. There is no need to ignore the obvious truth about theses cars. Also, we all know that the nhra rates these combinations on a curve so you will never see the actual Horsepower figure for any given combination show up in the Class guides.
BTW the new CJs are making much, much more horsepower than any 396 or 427 on the planet. This point is not in contention.
Bruce Noland 1788 STK
Old 02-20-2009, 03:28 PM   #52
GUMP
Liked 2,355 Times in 554 Posts
OK Bruce if we are going to be fair about this how about we start out with your new Corvette? I will submit my Firebird numbers right after.
Old 02-20-2009, 04:03 PM   #53
Bruce Noland
Gump,
Best numbers 592 Horsepower and 557 Torque. This motor is nhra rated at 420 Horsepower.
Old 02-20-2009, 04:17 PM   #54
GUMP
Mine made right at 402 at the rear wheels and is factored at 341 HP. So, now what do we do? Mine is nowhere near the fastest, so can they even use mine? One dyno to the next will not read the same for many reasons, so how do we make up for that? Do you see where I am going with this whole dyno theory? There is no way that it can be done and give perfect results. Even if the the run is honest. I believe that the CJ is a soft combination, but I also don't believe that 500 HP is the right number. There have been lots of soft combinations before and I am sure that there will be many more. I really think that everyone should sit back and see what happens with this one. At least for a little while.
Old 02-20-2009, 04:39 PM   #55
Bruce Noland
Gump,
I'm sorry, this isn't a complicated issue to resolve. One of these motors will be on the dyno someday soon and it won't take very long to figure out where they really belong. Thanks.
Old 02-20-2009, 05:17 PM   #56
big blue galaxie
Gump,
Thanx Bruce, you got what I was getting after. It's not the Cobra Jet per se, it's how the whole issue got handled and where it and other cars like it fit in the scheme of things. Someone brought up the new ZR1 and that car, if it was available in a drag chassis like the CJ and underrated the same way would cause the same controversy. All Ford had to do was be straight up about the true hp of the car and let the factoring fall where it may.
big blue galaxie is offline   Reply With Quote
Old 02-20-2009, 06:52 PM   #57
junior barns
Liked 20 Times in 14 Posts
big blue galaxie
AAAAAAAAAAAAAAAAMEN
Ford, GM, chrysler, makes no difference
junior barns is offline   Reply With Quote
