Liked 205 Times in 93 Posts
time for a fuel cell and i need your thoughts......alum. or plastic ? thankyou.
Aluminum
Bill Belden Retired Stock Eliminator [emailSTK1100@comcast.net[/email] |
Aluminum!
Shawn Blair 6383 SS 634 STK |
Liked 19 Times in 7 Posts
aluminum is trick but check for leaks before installing. I have 2 bungs welded on mine and the welds are tiged mint...but I have a trunk that smells like fuel because of a small pin hole. The leak is so slow that the fuel actually evaporates before it has a chance to drip but the smell is still there.
Tony Valerio 1968 Camaro 1700 IHRA H/CM 1701 NHRA SS/?A |
Plastic as well mine stinks unless only 1 gallon always thought was venting problem. Had to respond no help here that gremlin still lives in garage.
use aluminium, mine is a RCI and so far no problems. only wish it had a -10 outlet.
Dion Hildebrandt 6009 STK H/SA |
the alum. 5 gal unit from jaz has -8 outlets.
