Liked 4 Times in 2 Posts
Can someone explain to me what the purpose is in what I think they call "scaling" a drag car? I am asking about the process of weighing each four "corners" of the car, and making each "corner" a certain weight or percentage.
Is this something that a person would do to a leaf spring camaro or firebird? If so, what would be the proper percentage of weight per corner, etc.? THANKS! |
Liked 359 Times in 103 Posts
Scaling a car is to setup the suspension to plant the rear tires and go straight on the launch.
It can be done with the four link or ladder bar suspension. It also allows you to keep the front end square with the front wheel equally loaded on the launch which will keep the car straight. I am not sure how anyone would do it with a stock suspension. With a good set of scales you can setup a car in the garage and have it ready to race as far as the suspension is concerned before every taking it down the track. My 2 Cents |
Liked 16 Times in 11 Posts
Yep, Stocker's do it too. done with you in car, balance weight and move as much to the rear as possible.
Bob Pagano A/SA |
Liked 4 Times in 1 Post
Scaling is very helpful if you just built a new car, or it has been in storage a long time, or in a crash. It can save a lot of time if it pulls to one side as well.
If you install a stiffer spring in the left front, the wheel weight of the right rear will increase. The opposite corners effect each other, no matter what type of suspension. Also, the preload adjustment on Caltracs have an effect as well. I had King Race Cars scale my 69 Camaro a couple years ago. He heated and bent one front coil to get the rear wheel weights about equalized. I'm sure that I recorded the corner weights in that year's log book. If you are interested in knowing the numbers, send a PM, and I'll dig out the books and try to find the info.
Tony Curcio 1860 STK Last edited by Tony Curcio; 03-27-2009 at 06:12 PM. |
Thanks for the replies everyone!
dt |
Off the trailer the corner weights were as follows:
LF- 956 RF- 910 LR- 811 RR- 706 After raising the LF spring rate 50 lbs, the rear wheel weights were about equal, then the Cal-Tracs were re-set according to mfr instructions: LF- 1006 RF- 863 LR- 756 RR- 772* *16 lbs preload
Tony Curcio 1860 STK |
#8 | |
Liked 795 Times in 210 Posts
I'm guessing the driver is in the car with these wt. numbers ??
"Pistol" Pete Dutko |
Yes, 220 lbs in the driver's seat. The front weights are not critical on a drag car. The object was to get some balance on the drive tires.
OK Thanks Tony.
