#11 |
Liked 70 Times in 22 Posts
Believe the head for both the S/SS Challenger 5.7 and 6.1 is the 369AA head from the 6.1 SRT8 with larger valves. The Manley rod wont work. Has to be 6.200" + or - .025. I don't know of a Mopar rod that is 6.200" so my guess is it is aftermarket or Mopar special built. Since they use Diamond pistons, they might know. The 6.1 SRT-8 crank is a forged piece. Knife edged I am told. I will be picking one up Monday and will know for sure. They will interchange but you have to go with the 6.1 front cover and balancer.
#12 |
Sonny said the throttle body was a 1000 cfm piece. Dang! At 275 hp it will be an easy SS/J car.
Ed Wright 4156 SS/JA |
#13 |
Liked 325 Times in 50 Posts
All the T/B's are 1000 cfm 1.75 X 1.75 Stock cam in the 6.1 is .590 or so
Jeff Teuton 4022 STK |
#14 |
One thing about it, a 4 hole throttle body is a lot easier to tech than 30-40 year old carb. Are the valves hollow stem like in the factory 6.1 SRT8? Would be nice if Mopar said they were both sodium filled.
#15 |
Liked 8 Times in 5 Posts
All three engines have unique features that are different from the OE versions. Check the spec's carefully.
