Old 05-01-2009, 02:40 PM   #11
bill dedman
Liked 6 Times in 4 Posts
Default Re: Aluminum 8 3/4 Housing
Bob,
That'll happen when Ford buys G.M. and resurrects/exhumes Pontiac.
Bill
Bill
bill dedman is offline   Reply With Quote
Old 05-01-2009, 09:32 PM   #12
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Bill,
I guess that's like the AMC / MOPAR shotgun wedding that put Dana 60's in the AMX.
Just to set the record straight, the last Pontiac rolled off the assembly line 28 yeras ago in 1981.
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 05-01-2009, 10:06 PM   #13
herbjr
Liked 83 Times in 32 Posts
According to the GURU's a Dana is .2 slower anway. Thats why I just put one in my 3745lb stocker.
Herb Jr
I'm not a GURU
herbjr is offline   Reply With Quote
Old 05-02-2009, 12:46 AM   #14
Jeff Lee
Jeff Lee's Avatar
Bob,
FYI, NHRA told Evans to take out his aluminum 9" center section. Even after it appeared in ND as a tech article. It falls under "no light-weight components unless otherwise specified" in the rulebook. Obviously there are many loop holes under that category.
Please email me at the address below. I want to discuss something else with you.
Thanks,
Jeff
Jeff Lee 7494 D/S '70 AMX
Old 05-02-2009, 07:36 AM   #15
bill dedman
Jeff,
Thanks for that information.
Bill
Bill
Old 05-02-2009, 07:44 AM   #16
RJ
Originally Posted by herbjr View Post
According to the GURU's a Dana is .2 slower anyway. Thats why I just put one in my 3745lb stocker.
Herb Jr
I'm not a GURU
I heard "Bocephus" is getting a promotion to SS, what combo you going with?
p.s. - coolest car I've seen in years.
RJ is offline   Reply With Quote
Old 05-02-2009, 10:13 AM   #17
340Cuda
Liked 805 Times in 341 Posts
Herb Jr
I'm not a GURU
I am no GURU but my personal experience has been that the better pinion placement on the Dana made up for the extra weight. I switched from an 8.75 with a spool to a Dana 60 with a spool (same axles) and the only real change was I quit breaking gears. The car seemed to run exactly the same.
I saw a post from Larry Hill earlier that switching to a Dana did not slow him down, although I assume he was able to maintain the same weight by removing ballast.
Maybe you are saying the same thing but being more subtle :-)
Bill Lamb
Old 05-02-2009, 11:35 AM   #18
George Mirza
I have heard of Max Wedge cars going faster with the Dana's. Just look under John Shaul's car, if it will make it faster it's on John's car.
George Mirza is offline   Reply With Quote
Old 05-02-2009, 08:33 PM   #19
Jeff Lee
Jeff Lee's Avatar
Years ago Car Craft did a back to back at the track test of an 8 3/4 to a Dana 60 in an A-Body. No difference.
Old 05-03-2009, 09:42 PM   #20
herbjr
I have done this to two different cars and the A body car worked better with the Dana. The wagon we changed alot of stuff at once but its .07 quicker in 60 now than it was 2 weeks ago.
Herb jr
