Old 06-06-2009, 12:15 PM   #1
Lynn A McCarty
Lynn A McCarty's Avatar
Default Motorhome Error codes
Can anyone provide engine error codes for a 1998 Winnebego Motorhome w/GM chassis Class A Vortec 454 L-29?......and the procedure for determining them? Cant find it anywhere!
Frustrated,
Lynn A McCarty 3470 SS
Lynn A McCarty is offline   Reply With Quote
Old 06-06-2009, 01:04 PM   #2
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Re: Motorhome Error codes
I am asuming you mean check engine code numbers. You will need a scan tool or if you goto autozone they will usually pull them for you. If you get the numbers and send them to me I would be happy to look them up and tell you what they are. The aldl connector should be beside the doghouse on one side or the other or under the dash on drivers side. Unfortunetly the days of retriving codes with a paper clip ended in 94
Old 06-06-2009, 04:07 PM   #3
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
well, 95 actually....
althought there was some obd2 in 95...
and yes, you'll need a scanner..
Old 06-06-2009, 07:10 PM   #4
Ed Wright
Ed Wright's Avatar
Actually, 1993 for some GM passenger cars. Like the LT1s and many 3.1L V6 FWD cars. I get calls all the time from guys trying to pull codes from those cars with a paper clip. It's pretty much plug-in proms you can, flash memory you can't.
Ed Wright 4156 SS/JA
Old 06-06-2009, 07:13 PM   #5
njk53
Actually, GM started to phase in OBDII in 1994. My dad's 94 LeSabre has it.
Nelson Kowal
Stock 345
Old 06-08-2009, 09:44 AM   #6
Ed Wright
Ed Wright's Avatar
Actually, the OBD2 style connector under the dash does not make the vehicle OBD2. 1994 LeSabres were still OBD1. The '94 & '95 GM vehicles with the newer connector do not have the class 2 data terminal and wiring. The '94 & '95 Corvettes, and 1995 F body cars all have the OBD2 style connector below the dash, but are not OBD2. Actual OBD2 GM cars and trucks came along in 1996.
Old 06-08-2009, 11:48 AM   #7
bobby
bobby's Avatar
My 94 firebird v-6 has a obd1 plug but you can't read it with a paper clip. It's one of those bastard years tha you have to have a scan tool.
Next time wave all of your fingers at me.
bobby is offline   Reply With Quote
Old 06-08-2009, 12:20 PM   #8
Ed Wright
Ed Wright's Avatar
Bobby, it has a flash PCM, not a removable prom. Flash computers all need a scan tool or code reader. Not all flash computers are OBD2 however. Not until 1996.
Old 06-08-2009, 01:33 PM   #9
bobby
bobby's Avatar
Wondering why the paper clip wouldn't work.
Old 06-08-2009, 02:50 PM   #10
Mike Gray
Mike Gray's Avatar
Liked 685 Times in 196 Posts
Try this web site:
http://www.irv2.com/forums/
Mike Gray is online now   Reply With Quote
