Old 07-15-2009, 08:58 AM   #1
gofastorgohome
Default Block modification?
Any opinions on modifying a block to accept a larger journal camshaft in a motor for Stock? I've heard differing opinions from different tech folks but am curious if anything "official" has ever came from Glendora. I have my own opinion, but am curious what kind of "discussion" this may generate...
gofastorgohome is offline   Reply With Quote
Old 07-15-2009, 11:21 AM   #2
gofastorgohome
Default Re: Block modification?
Do you know of anybody torn down that has done this block mod. and passed?
Old 07-16-2009, 08:28 PM   #3
gofastorgohome
Talking Re: Block modification?
Wow! The silence is deafening...LOL. That's the response I thought I'd get... at least we are predictable.
Old 07-17-2009, 12:01 AM   #4
Tom Moock
Liked 10 Times in 6 Posts
Gofastorgohome, Are you talking about roller cam bearing? I no expert on the subject,but I was told you have to use a billet cam and you have a problem with lifter`s, They said nascar racer`s have a way to do it, but it`s high dollar. I don`t know about motors that run stock roller lifter`s. Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 07-17-2009, 07:59 AM   #5
gofastorgohome
[QUOTE=Tom Moock;130295]Gofastorgohome, Are you talking about roller cam bearing?
No, I'm talking about the ability to use a larger radius for the lobes to be ground on.
Old 07-17-2009, 08:53 AM   #6
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
You can buy them if you want one. Have'nt looked real close but I don't think rules say you can't run one
if that is correct means probaly have'nt caught one therefore no rule yet? I think I know guy who had
vaccumn leak rule made after.My Dad told me in early 70's @BlueGrass& Clay City ,Terry Butcher had 2Bbl stocker 60 chevy?
283 Idled so rich could'nt stand behind it revved it cleaned out ran way under record eventaully pulled air cleaner off carb had springs holding down, linkage short, when wide open raise carb off intake, he said a couple weeks later Natl. dragster had rule revision about vaccumn leaks,whether Terry caused that rule
or not I'm not sure but I think he was close.
Mike Taylor 3601
