Old 07-17-2009, 03:18 PM   #51
Ed Wright
Ed Wright's Avatar
Default Re: 2010 Camaro / 425 HP
Bobbie, I had just what you need for your new Camaro in here yesterday. A black 6 speed SS version brought here for tuning with an ATI Procharger. ATI brought it down. After I tuned it, with 7 lbs of boost it made 542 rwhp, with 6 lbs (different pulley) it made 526. Very conservative tunes. New car, still had the paper dealer tag. Just what you need for yours.
Ed Wright 4156 SS/JA
Old 07-17-2009, 03:35 PM   #52
Ed Wright
Ed Wright's Avatar
A thought about racing one of those. Your gonna need a wide trailer. I had to help the guy put that one back in the trailer for the return trip. A new ATC trailer, and there was very little room on each side. It was close enough he wasn't comfortable loading by himself, and he loads & hauls a lot of cars in his job there. He said none so far has been that wide. Had to pull one ramp door cable out so the mirrors could clear.
Old 07-17-2009, 04:21 PM   #53
7820
7820's Avatar
Ed when you do your work is the warranty still valid??
7820 is offline   Reply With Quote
Old 07-17-2009, 07:14 PM   #54
Ed Wright
Ed Wright's Avatar
I doubt GM would be interested in a warantee for one that had a supercharger added as that one did. They don't want the calibrtion tampered with at all. I don't think a person that would modify their new car should expect the warantee to cover anything they modified.
Old 07-17-2009, 07:24 PM   #55
W J
Try taking one in for warranty service w/a re-programmed PCM.....
Old 07-18-2009, 07:31 AM   #56
rayfin
Why did they build them so heavy? Gas milage? If the corporations go bankrupt does that mean you don't have to pay for them?
rayfin is offline   Reply With Quote
Old 07-19-2009, 11:29 AM   #57
ken robinson
Liked 224 Times in 87 Posts
I think G M screwed up by making the higher HP camaro stick only again and the IRS is a pricey alittle problem . But Jacks GTO leaves as nice as it looks . What classes will it fall into coupe vs conv ???
Old 07-20-2009, 07:43 AM   #58
W J
Friend bringing his auto '010 SS up to New England Dragway for its track debut probably on Sat. 25th for some testing....like said, 3600 stall, re-tune, headers, Nitto drag radials (20"), a few other things.....we will see..... showed only 360 (unlocked and low miles) on dyno....a heavy sled, but have to start somewhere...pure stocker coupes are running mid-low 13's.....anyone else here fooling around w/one of these cars at present? Stay tuned....WJ
