Old 08-20-2009, 08:04 PM   #11
RPM5595
RPM5595's Avatar
Liked 32 Times in 14 Posts
Default Re: Car falls down as it leaves line
I had a VERY similar problem a few years back. LONG story short, it was the battery. My battery was mounted lengthwise in the car at the front and apparently it had a cracked plate or two. When I would launch the plates would touch and ground out I suppose and the engine would flat die but then it would recover and run fine the rest of the run. Hope this helps.
Jay Roeder
Jay Roeder
facebook.com/racefuelsales
Former N/SA , Soon to be SS/AS, Renegade Race Fuel dealer
RPM5595 is offline   Reply With Quote
Old 08-21-2009, 06:53 AM   #12
Greg Hill
Liked 279 Times in 68 Posts
Make sure you have the gasket between the top and the body taped where the secondary metering rods go through it. Gas can come through there and cause a stumble.
Greg Hill 4171 STK
Old 08-21-2009, 11:09 AM   #13
Isaac Zane
Isaac Zane's Avatar
Liked 50 Times in 14 Posts
I'd go with Greg's answer. He had the same problem with the Buick. Time for new tape!
Isaac Zane STK 1237
J/SA Buick Apollo
Patriot Guard Rider DOOF 43
Isaac Zane is offline   Reply With Quote
