Old 08-25-2009, 06:23 PM   #1
Bob Gullett
Bob Gullett's Avatar
Liked 507 Times in 116 Posts
Default Cal Trac Shock Mounts
Any one ever have one break? Just came back from Acton and went to unload the car and noticed the left rear shock mount was broken. Just curious.
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 08-25-2009, 07:01 PM   #2
Jeff Teuton
Liked 325 Times in 50 Posts
Default Re: Cal Trac Shock Mounts
I broke one that I had modified, and I found a crack in another. Both were in a 3600 lb 700 hp Hemi on 9" tires. I think I cracked the one in the trailer. I have broken more suspension parts in the trailer over the years than any other way. When I go long distances, I tie both cars down really tight-forward backward and pull the suspension down.
Jeff Teuton 4022 STK
Old 08-26-2009, 04:46 PM   #3
Bill Edgeworth
Had the same thing same side after getting home from Sonoma
Bill Edgeworth 6471 STK
Bill Edgeworth is offline   Reply With Quote
Old 08-26-2009, 04:57 PM   #4
Bob Gullett
Fortunatly I had a spare set so I changed them (believe it or not bought them at a local swap meet a year ago). I think they need to gusset them and make them a little stronger.
68 Chevy11 327 F/S
Old 08-26-2009, 10:03 PM   #5
Scott Loge
Liked 145 Times in 32 Posts
Broke 1 on my GTX at Pomona and John Calvert had one brought out and assisted in the swap to make sure I could MAKE THE NEXT RUN.
DON'T SEE THIS VERY OFTEN.
QUALITY PEOPLE ARE GETTING HARDER TO FIND
MINE HAPPENED IN TRANSIT AS WELL
Scott Loge is offline   Reply With Quote
Old 08-27-2009, 04:11 PM   #6
Stick Racing
I don't have Cal Trac's on my car but something similar. I haven't broke anything but have bent the lower mounting bracket.I found the reason was the suspension was separating so much at the starting line, the shocks are running out of travel. Needed to put some extensions on. No problem since.
____________________________________________
Andy Stone A/S 1102 SS/C 1112
Stick Racing is offline   Reply With Quote
Old 08-28-2009, 02:28 PM   #7
SmallBlockNova
SmallBlockNova's Avatar
Send a message via AIM to SmallBlockNova
I bent a lower bracket and cracked one of the shock brackets. I heated it up with a torch, straightened everything on a 1/2" thick steel table, then dropped it in a bucket of oil while still hot...I then added a few gussets and I haven't had a problem since...
SmallBlockNova is offline   Reply With Quote
Old 08-29-2009, 11:19 AM   #8
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
are all you guys using older cal trac stuff? Mine are about a year old now...just wondering if they have corrected the problem already. I havent had any problems but then again I havent been inspecting them closely. Everything seems tight but stuff breaking in transit and not knowing about it could cause some major problems. I guess some bracing wouln't hurt. Should I worried on a low 11 second stocker?
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 08-29-2009, 05:04 PM   #9
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
From John Calvert himself.
We have seen mounts break or crack where the shock hooks up. I feel the main reason for this occurrence is how cars are transported. Tying to the rear end housing and allowing the body to remain free allows everything suspension related to move, couple this with some of the freeway conditions and realize that the Rancho rear shock set to a nine has tremendous resistance the loads are just really high.
I won't use the tie-down method as a reason not to take action and I haven't. I have crept up on it over the years. Trying to stay with highest levels of performance employing the least amount of weight we changed the design so that the area would have more structure, we tried gussets, material thickness. Our latest design seems to be working the best so far (early 07) with no reported problems since. Again, a vast majority of our customers will never have a problem even with the bars we manufactured in the mid ninety's. I do feel a discussion on tie down method would benefit many racers and not just because of this issue. All the suspension components and even the handling of lightweight tow rigs are affected by how the car is anchored.
Thanks for the info, forward this on if you like.
John Calvert
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
Old 08-29-2009, 11:01 PM   #10
Liked 5,125 Times in 1,953 Posts
I would agree that probably 95% of the flexing occurs while towing. I would suggest fixing some kind of temporary stanchion under the rear frame somewhere. Just tightening down the rear (of the car) until it doesn't move anymore, just does not seem like a good idea.
