#51 |
Liked 109 Times in 44 Posts
#52 |
Liked 3 Times in 1 Post
The cam gears on these engines are not keyed, so you have to use a set of special locks to position the 4 camshafts and the crankshaft and them you torque the canshaft sprockets on, the camshat and sprockets are a tappered fit. OTC makes a master kit thats does most Fords but the DOHC need another kit that is also by OTC around $300.
Chris |
#53 |
Liked 91 Times in 2 Posts
The whole situation with Tim Bishop is probably the worst that I've seen in years. NHRA did not do the right thing here. There was nothing wrong with his pistons and this engine was built by one of the most respected engine builders in Stock Eliminator.
What really amazes me is the fact that CP pistons and NHRA are suppose to be on the same page and working in concert together in this world of Stock Eliminator that we live in. Both parties are suppose to know what the other one is doing and wants, but it's 180 degrees the other way! Chaos! No communication skills at all, that's for sure! When you're dealing with the expenses in getting to Indy, and all it takes to maintain a race car, there is no excuse for what happened here. T. Bishop should be given the class win in this situation. This issue is between CP and NHRA. Not the racer who was legal in all parameters of his engine. Jerry |
#54 |
Liked 7,779 Times in 1,742 Posts
Jerry, I think that it's terrible what has happened to Tim. I brought this issue (part #s) to techs attention over a year ago. If a piston, pin, rod assy looks and weighs correctly then what difference does it make what part number is on it. I was told they needed a part # for "reference" purposes. As bad as what happened to Tim is I still feel what happened to Don Himes at Indy a few years ago is worse. He won class and was tossed out of the barn because his heads looked "too stock". That is the direct quote.
#55 |
Guess you don't sand the tops of those to equalize the deck! About all you could do is cull through rods for slightly different lengths (not real likely with aftermarket rods) and/or re-size some to shorten them. What a pain if your somewhat anal and like everything dead-nuts. Makes SS engines look easier.
Bite me, Short Bob.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 09-06-2009 at 07:46 PM. |
#56 |
Liked 370 Times in 101 Posts
Mike, so it is my understanding that your team's attention to detail is also "illegal?" After all, your engine was once found to be "not correct to specification."
Guess what? These things happen and most of the time nobody ever hears about it. I don't recall seeing a post for you guys, "Voth OUT at KC!!!" The story about Ford sending in the wrong spec is entirely possible and this (small) issue will be resolved, just like most other tech violations. And in the interest of fair reporting, would you (and many others here) be making such a big deal out of this if it was a supercharged LS7 Camaro or Corvette that got tossed for the same violation? Just saying.
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
#57 | |
Liked 1,436 Times in 299 Posts
James Schaechter 3163 STK |
#58 |
Liked 136 Times in 49 Posts
Jason Line got a year way back for a illegal piston. Will these guys get a year?
#59 | |
Liked 57 Times in 14 Posts
And, seriously, rules are rules, and even though it doesn't make a difference overall, NHRA made the right call, as they did with us in KC last fall. We corrected ours, they will correct the CJ's paperwork, and we'll all move on like we always do.
Mike Voth 5189 GTN - 5188 GTO Voth Racing Last edited by Mike Voth; 09-07-2009 at 12:46 PM. |
#60 |
