#11 |
Liked 333 Times in 180 Posts
Well for whatever its worth Flatout is/was started and staffed by several of the Fel-Pro employees when Fel Pro scaled back their hi perf division which was about the time they went into bankruptcy and pretty much left the racing arena---Give em a call cant hurt---They won't BS you that's for sure---If they know the answer to your ??? they will give you the honest truth--- Cometic has a very good product to not bashing them at all---Comp 387
#12 |
Liked 19 Times in 8 Posts
Dennis 3995633 is the correct number they are .017 thick you may have to stack them depending on the deck
Joe Schweigert 751 SS |
#13 |
Liked 7 Times in 7 Posts
The .017 number mentioned is the compressed thickness, right? What is the "squished" number when you stack 2 gaskets? I've heard that it's not necessarily .034, or did I hear wrong?
#14 |
Liked 5 Times in 3 Posts
I bought the 3995633 maybe 6 months ago but now are no longer available from gm. Did a little comparison with the 4.0 bore gasket and the difference in compression turns out to be almost nothing, 10.639 to 10.632. Looks like I will stock up on the bigger one.
Thanks for the help |
#15 | |
Liked 3 Times in 1 Post
Wade |
#16 |
Liked 780 Times in 194 Posts
I spoke to the head of production at Detroit Gasket (the company that supplies Chevrolet with these gaskets) a few years ago about the steel shim gasket situation, and he said their dies are just too worn out to reliably produce good stampings for the 633 pn. He was willing to make another run if someone would belly up for 1000 gaskets and be willing to pay for culls. He said GM told him that the last batch he produced in 1999 would be the end for them because of low demand.
#17 |
Liked 1,436 Times in 299 Posts
Here are the Cometic Head Gasket choices for thickness. Jim
.027 .030 .036 .040 .045 .051 .056 .060 .066 .070 .075 .080 .084 .086 .089 .092 .095 .098 .120 .140
James Schaechter 3163 STK |
